84 LE FWD water pump pulley removal. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-14-2011, 06:24 AM   #1 (permalink)
a992156's Avatar
View a992156's Photo Gallery
USA 84 LE FWD water pump pulley removal.
Hi all first post here. I should've been coming here a long time ago.
Going to replace the timing belt and water pump on my 84. Is there a tool to hold the water pump pulley in place to get the bolts off? The pump needs to come off to get to the t belt. Looks like I'll have to jack the engine up and down to get the bolts off as well.
Tried searching, but didn't find anything.
a992156 is offline   Reply With Quote
Old 04-16-2011, 08:12 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
The way I do it, is to loosen those bolts before removing the drive belt, and stick a wrench through the P/S pump pulley, which is on the same belt.
This is on newer fuel injected models, and I am not sure your '84 is the same.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
