will these fit my car? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 04-15-2011, 01:03 AM   #1 (permalink)
View blulightandabat's Photo Gallery
USA will these fit my car?
i have an 87 ae82 corolla fx16 gts. will they fit? are all the 4 lugs the same on the old toyotas?
Heres the car
blulightandabat is offline   Reply With Quote
Old 04-16-2011, 08:05 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Those wheels are off a rear wheel drive model I belive. Celica or Corolla.
The offset (back space) is different from the front wheel drive models, and I believe the bolt hole spacing is different also.
If the bolt hole spacing is the same you could possibly use spacers, but for the thickness that I think you might need, you will probably need to get longer wheel studs too.
There are some adapters (spacers with wheel studs in them) that will correct for back spacing and bolt spacing, but those cost so much, it is probably better to just get yourself a set of inexpensive aluminum wheels from Discount Tire, or find some in a salvage yard, that will fit.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 04-17-2011, 12:09 AM   #3 (permalink)
No More Turbos!
View Pwner Guy's Photo Gallery
Those look to be MKII Celica Supra wheels so you're looking at the wrong offset and bolt pattern. If you had a RWD Corolla they would work however on the FWD they won't. RWD four bolt has a 4X114.3 bolt pattern, FWD are 4X100. As Donald pointed out you can buy adapters but it'll be about the same cost just to pick up a cheap set of alloy's. You can find them now for $100 a wheel for the low end ones or you could search the junk yards for a used set, lots of cars used/use the 4X100. Older Hyundia Elantra's, Honda Civic's, Tercel's, Paseo's, Echo's, Yaris' and Ford Escort's all had/have that pattern, biggest thing is making sure the offset will work for you.
Richard Hammond - You can stick a BMW badge on a dead cat... And people would still buy it.
Pwner Guy is offline   Reply With Quote
Old 04-17-2011, 01:53 PM   #4 (permalink)
Donald's Avatar
The first three wheels at the link below are less than $65 each.
14" wheels
http://discounttires.com/list.php?di...arch=wheelsize
With 15" wheels, you have a greater selection.
15"wheels
Old 04-19-2011, 04:54 PM   #5 (permalink)
Donald's Avatar
Sorry. Those links I put up befor were for some other Discount tire, not the one I was thinking of.
I thought they had changed their web site, but was wrong.
Here is the Discount Tire I was refering to.
http://www.discounttire.com/dtcs/fin...-100*9-100&rw=
