Can I use Nova parts? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 06-11-2011, 05:41 PM   #1 (permalink)
View kyotee's Photo Gallery
I have a 1987 Corolla DLX FWD sedan that suffered a broken timing belt and now has almost no compression in no's 2 and 3. I am concerned that I may have some bent valves (or worse).
I found a 1988 Nova that has fewer miles but has some body damage that can be had for cheap.
1. If these are both SOHC 1600's will the Nova head fit my motor?
2. Will anything fit?
3. Do I need to remove both manifolds to pull the head or can it be done by just disconnecting the header pipe and pulling it all out at once?
Any help would be appreciated.
kyotee is offline   Reply With Quote
Old 06-22-2011, 08:55 PM   #2 (permalink)
View uraverageyota's Photo Gallery
is it a 4alc motor as well? i had an 86 fwd once upon a time but those yrs r long since passed. If its sporting the same motor i would have to say yes a lot of the important parts should b interchangable. The biggest difference was body panels and lights.
uraverageyota is offline   Reply With Quote
