Yes and no, the SR5 and GTS are both AE86's. But that's an argument I don't really want to get into.
The GTS rear end is stronger than the SR5 rear end, but if you're swapping in a SR20DET, you should really look at getting a stronger rear end anyway. I don't think the SR5 rear will last more than one clutch kick/burnout with an SR motor, but a few people seemed to have kept a GTS rear together even with a modified SR plant.
You'll also need to run a fuel return line, or set up the fuel system to BE a return-less system, since the SR5 doesn't have a return line like the GTS because it's carb'ed vs fuel injected. The wiring should be the same headache, and you'll have to get a mount kit or fab mounts and cut a new hole for the shifter anyway, so those won't change between a GTS or SR5 chassis.
Physics for your head!!
2000 Camry XLE 5-Spd
1985 Corolla GTS Coupe
