Vacuum problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 07-14-2011, 01:09 PM   #1 (permalink)
View anthonyhasawagon's Photo Gallery
AE86 Vacuum problem?
I have an 83 corolla wagon and it seems to hesitate at slow speeds and it feels like i have to hammer down on the throttle. At higher speeds(>35) its fine. just getting there is the problem. I ruled out the possibility of it not starting in first gear by driving it in Low gear and manually shifty into second and then into drive. and it ran the same.
I just bought the car and it failed smog so what i had to replace is as follows:
Cap
Rotor
Wire set
Spark plugs(.44)
evap hose from my canister
gas cap
fresh air intake hose
preheater hose
about 2.5 ft of vacuum line
I'm pretty sure its a vacuum problem i just want to be sure. I'm gonna replace the fuel filter soon to see if that rules it out and maybe buy some carb/choke cleaner.
Has anybody else had this problem or similar?
anthonyhasawagon is offline   Reply With Quote
Old 07-17-2011, 10:28 PM   #2 (permalink)
Wonderbread
4agetercel's Avatar
Gameroom cash: $160040
View 4agetercel's Photo Gallery
fuel filter could defiantly be an option, as could a dirty carb
whats your milage?
4agetercel is offline   Reply With Quote
Old 07-17-2011, 11:09 PM   #3 (permalink)
It has relatively low mileage for being a 1983. its around 182k
Old 07-18-2011, 09:27 AM   #4 (permalink)
Wonderbread
4agetercel's Avatar
182k miles? thats almost 300k km's.... thats a rather high milage engine if ya ask me, and a dirty carb and fuel filter would be definitely somthing to look into
Old 07-23-2011, 04:01 PM   #5 (permalink)
the butterfly in my carburetor was sticking. Took some carb cleaner to it and cleaned up real good and its runs better. still have to change the fuel filter.
Old 09-01-2011, 09:31 PM   #6 (permalink)
i found vacuum lines that were spliced together that i didn't see when i changed some hoses and it fixed every performance problem i had
f**k vacuum lines
Tags
4ac, ae86, badass, station wagon, vacuum
