Originally Posted by anthonyhasawagon
what did you use for the constant power supply? I think mine has a inline fuse somewhere and i can't find it. And i think i burnt it out trying to install 9my radio. I tried taping into the cigerette lighter cuz i thought it was constant (it's switched) so as of now i have no memory on my deck :|
There should be two factory connectors behind the dash, a 2 prong and a 4 prong. The 4 prong is for OEM speaker wiring, the 2 prong (blue-white/black) provides unswitched power and ground, at least in my car.
I'll take a couple of pictures for you when I tear the dash open again to fix the switched +12v connection.
The new stereo requires discrete ground connections for each speaker so I ended up creating a much larger harness using two 9 pin connectors, tying into the aftermarket harness it had when I got the car and adding a second molex connector for the rear speakers/switched outlet wiring.
I'm very unimpressed with the (broken?) factory antenna. I'd always assumed it was the radio tuner that was flaky, but even with the new deck I can only scan 5 FM channels. If I wasn't planning to use it almost exclusively for mp3/streaming audio I would be pretty annoyed.
