In this post, I am providing the repair-manual pages, actual photos, and a few warnings if you intend to rebuild your carburetor.
Here is the Fuel System chapter from the 1985 Toyota Corolla FWD Repair Manual for the Aisan carburetors, including 16030.
IMPORTANT: In order for the pages to display correctly, use View --> Page Display --> Two-Up in Adobe Acrobat Reader.
Toyota Corolla 1985 FWD Repair Manual Fuel System (Aisan carburetor, including 16030)
Here are the photos of the rebuild of the 4A-LC Aisan 16030 carburetor of my 1985 Corolla LE (FWD) with US Federal emissions:
Toyota 4A-LC Aisan 16030 carburetor rebuild -- complete teardown
Good luck rebuilding the carburetor.
A few warnings:
- Get a Great Neck impact drive from Autozone to be able to remove the flange screws without damaging them.
- Use a quarter-dollar coin in the needle-valve strainer and turn it with pliers.
- A sawed-off flat screwdriver may be useful for removing jets.
- You need a very thin-walled 9 mm drive to be able to remove the power piston.
- Take a photo at every step so that you can put things back correctly.
- Larger jet is the secondary jet, smaller is the primary.
- Be very careful not to drill into the idle-mixture screw. Go very slowly. Punch a dot in the exact center of the MAS plug first so that the drill bit will be stable. The screw is only 2 mm under the plug.
- Use goggles when you use compressed air with carb cleaner so that you don't get it in your eyes.
- You can use short teflon-tubing pieces to replace broken plastic bushings.
- Don't damage the cold-mixture heater. They don't make it anymore. It only makes a complete circuit when it's installed and don't incorrectly assume that the heater wire is broken -- it's not.
- Get the correct flange gaskets if they don't come with the kit. Chances are that they won't. You can also make your own gasket from FEL-PRO sheet gasket material -- readily available and cheap at auto stores -- probably much higher quality than aftermarket gaskets in the kits.
- Don't overtighten any mounting bolt or screw. if you tighten the gaskets too much, they can start leaking in a few years.
