weber 32/36 install problem help... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 10-30-2011, 02:21 PM   #1 (permalink)
Back in Da Old Dayz
Darien18's Avatar
View Darien18's Photo Gallery
hi guys just installed a weber 32/36 with the holley fuel regulator on my 2tc
at 1st i install it with out the fuel regulator and it would run but fuel begins to
leak from under the motor around the oil pan but dont know eactly where its leaking from.
i smelled the dip stick and oil cap and i smell gas.
2nd i installed the fuel reg and it would run but idles kinda low but once i unplug the hose
(picture below) the rpm shoots up and fuel will start leaking
3rd i put a fuel return but it still would leak or is this for the vapor canister port?
cant find were the leak is coming from all i know its somewhere under the motor close to the oil pan
can someone tell me why im leaking fuel. is it flooding?
Darien18 is offline   Reply With Quote
Old 10-31-2011, 02:25 PM   #2 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152050
View hardtopte72's Photo Gallery
I am 99% sure your fuel pump is leaking. The fuel pump is driven by the camshaft and is located under the intake manifold next to the oil filter.
As for the fuel return I just cant remember without seeing it close up but i think that is the fuel return.
As for the vapor canister. Unless you are in a smog state I would say remove it. 99% of the time they are no good anyway as they are too old and saturated.
For a 32/36 I have never run a fuel pressure regulator. The stock regulator is always good for webers and stock fuel pumps. You need the regulator if you run holley fuel pumps and stuff like that. As for the oil cap and dispstick smelling like gas you need to check that out asap. It sounds like you are pumping fuel into the vacuum port of the carb and not the fuel port and it is dumping fuel into the engine. First check your fuel pump and look at the fuel lines. There should be one fat hose that is obviously the supply line and one that should obviously be the fuel filter line as it will be thin and connect to a soft line to the fuel filter. For the return you need to look for a similiar sized hose on the carb as the hardline that returns to the tank
Also change your oil asap. You dont want to damage the engine.
hardtopte72 is online now   Reply With Quote
