tail running lights are out - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-11-2011, 12:26 PM   #1 (permalink)
View graystephen's Photo Gallery
Exclamation tail running lights are out
The running lights on my 1980 wagon are not turning on. Head lights work, turn Signals work, brake lights work, back up lights work.
To be more clear, when I turn the head light switch to the first position no lights come on front or rear, when I turn it all the way, the head lights come on but nothing else.
I have replaced both rear bulbs(front are fine), the headlight relay, and checked any fuses I can find and all look good.
I'm lost at this point and can't drive at night because of it, anyone have any suggestions or tidbits of info that only an experienced owner might know.
PS I have used the search function, got two results and neither have any relation to what I am asking about.
graystephen is offline   Reply With Quote
Old 04-29-2012, 11:28 PM   #2 (permalink)
View corolla_nut_83's Photo Gallery
USA
So if all of your running lights are out I would say its a fuse problem. First thing I would do is change the "lights 15A fuse" in your fuse block with a known good fuse i.e a new or one that runs something else in the car that works. If that doesn't work I would make sure that your wiring harness in the rear of the car isn't smashed or broken. You might have a broken or open wire of some sort.
corolla_nut_83 is offline   Reply With Quote
Old 04-30-2012, 11:09 AM   #3 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $152050
View hardtopte72's Photo Gallery
Sounds like you have a bad switch that has failed internally. For some reason the power is not getting to the harness.
The long way is to check voltage at each connector for the running lights and at the switch. The short way is to simply replace the switch and see if it works.
My Toyota list:
1982 Corolla SR-5 Hardtop 5 Speed Manual(R154) 1JZGTE
2005 Corolla CE 5 Speed Manual 1ZZFE
2009 Camry LE 5 Speed Auto 2AZFE
If I helped out in anyway please hit the thanks button on my post .
hardtopte72 is online now   Reply With Quote
Old 05-02-2012, 11:29 PM   #4 (permalink)
it ended up being the switch on the steering column, i figured it out months ago sorry for not updating.
sadly I actually had to sell the car. I got a '90 rx7 in place of it, wasn't going to have the money for all the body work it needed so badly. Fortunately it is now in the hands of a trusted friend who has good plans for it.
thanks for the tips.
Tags
electrical, lights, tail lights
