car not starting need help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 12-24-2011, 05:19 PM   #1 (permalink)
ae86GT-S's Avatar
View ae86GT-S's Photo Gallery
so I have a 86 corolla sr5 to gts conversion, the fuel pump died so I bought a new one and swapped it out. when I try to start it up all it does it crank. so its a crank, no start condition. and even though I put a new fuel pump, I don't here it turn on when I go to turn the key on. I double checked if I hooked up the fuel pump correctly and everything looks fine. I'm kinda lost now and don't what the problem is.
any help would be appreciated thanks
ae86GT-S is offline   Reply With Quote
Old 12-25-2011, 09:18 PM   #2 (permalink)
View TheGreenMachine's Photo Gallery
...check your fuses and your relays first. if those are good, check for power thru your hot wires, do some voltage drops across your electrical components, check for shorts to grounds, etc. assuming your pump is good, make sure your ground has a good solid connection to your ground point.
TheGreenMachine is offline   Reply With Quote
