4ac timing help - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > Older Generations (1969-1987)
Older Generations (1969-1987) Specific discussion of the AE86, along with generations 1 through 5.
Old 09-10-2012, 08:36 AM   #1 (permalink)
View 80rolla's Photo Gallery
4ac timing help
I just bought an 84 Corolla SR5 rear wheel drive 4ac weber 32/36 carb and I'm having a problem with the timing if I line up crank and cam pulleys on the timing marks perfect then put mechanical timing at noon or facing 1 on cap won't start only way I can get it to start is by putting rotor facing the 4ac on the valve cover and then the timing is at least 40 out any suggestions?
80rolla is offline   Reply With Quote
Old 09-23-2012, 01:09 PM   #2 (permalink)
View corolla_nut_83's Photo Gallery
USA
I assume it runs poorly or at a fast idle? From what I'm reading out of this post is that you are some what mechanically inclined and you decided to change your distributor because of a no start condition?
With that being said, I believe you have the distributor in there correctly! It sounds like you have the cam off 1 to 2 teeth! The number 1 tower on the cap points at the 4a-c on the valve cover! But with the timing light being off 30 plus degrees (ignition timing being 4-10) I would bet money your timing belt is off just a touch.....
Maybe post a couple pics of your situation and maybe one of us can photo shop something for you!
corolla_nut_83 is offline   Reply With Quote
