Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - JL Audio Stealthbox for Tc. Your input please.
View Single Post
Old 06-15-2006, 04:21 PM   #1 (permalink)
JLTD
View JLTD's Photo Gallery
My car was in the R&D dept today to look over the application possibilities. I wanted something that would fit under the carpet and take the place of the PS foam storage. A 10W1v2 enclosure would fit, but it would leave only a .5" opening and that's not acceptable for output. Personally, I would go with a couple of 6W0 ported which would have the same power handling and output as the 10W1v2 sealed, but we will not make a Stealthbox with drivers smaller than 10".
Here is what the application will be:
a single 10" driver in a sealed enclosure
fits on the DS or PS (not both)
will not go under the carpet
Here's where I need feedback from Tc owners:
1 - Passenger or driver side? (we're leaning passenger side)
2 - Would you be willing to cut the side panel so a deeper woofer can be used?
A 10W1v2 enclosure would fit into that cavity area on the passenger side panel and look flush when it's done. If a consumer was willing to cut out a piece of the side panel, the appearance would be the same, but a 10W3v3 or 10W6v2 can be used. The extra depth would be in the area behind the stock panel.
3 - Stealthbox loaded with a 10W1v2, 10W3v3, or 10W6v2? The cost of the enclosure would be about the same, but the divers add to the cost. The Stealthox is shipped preloaded with the driver so there are no options. The SQ will be similar but the bigger divers handle more power so there is more output to be had.
4 - About 2" of the trunk floor flap will need to be trimmed off so you can still remove it to get to the spare and storage, is this acceptable?
5 - A Stealthbox with a 10W1v2 would retail $500 - $550 range
A Stealthbox with a 10W3v3 would retail $550 - $600 range
A Stealthbox with a 10W6v2 would retail $750 - $800 range
These are estimates. I feel that the 10W3v3 is the happy medium and is what most Stealthbox applications are loaded with. Which would you buy? It seems that many of the JL Audio systems Tc owners post have W6v2 or W7 so I could be wrong about this.
The goal of the Stealthbox is to minimally impact the functionality of the vehicle and create the best driver/enclosure combo. Much of the R&D time will be spent making sure that the system matches the sonic signature of the vehicle.
We start work next week so your feedback would be valuable.
Thank you!
JLTD is offline   Reply With Quote
