Dash Lights Out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2006, 01:19 PM   #1 (permalink)
View Mr Urban's Photo Gallery
Dash Lights Out
I have a 96 Toyota Corolla, I recently purchased an aftermarket stereo and when I installed it everything works perfectly, however the Dash lights went out, I checked the Fuses under the Driverside dash-all the fuses seemed to be okay. I disconnected the stereo to see if the Dash lights would come back on, nope.
Has anyone had this problem before, any suggestions?
Thanks
Mr Urban is offline   Reply With Quote
Old 02-19-2006, 01:46 PM   #2 (permalink)
TN User
Toumba's Avatar
View Toumba's Photo Gallery
i have the same problem
Toumba is offline   Reply With Quote
Old 02-20-2006, 12:38 PM   #3 (permalink)
Koo'rolla Lives Forever
New'rolla's Avatar
View New'rolla's Photo Gallery
it's a fuse....
i had that same problem.. but i looked in the fuses an there was a 15 blown... and it means your tailights, dash lights, and your markers are all out aren't they?
check the fuses again.
New'rolla is offline   Reply With Quote
Old 02-20-2006, 06:03 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Hey New'rolla!
BTW check the fuses under the hood by the battery also, there could be a fuse/relay in there that could have got burnt if you put the wrong wires together or if you grounded a power wire.
Old 02-20-2006, 06:30 PM   #5 (permalink)
View l_touring_dude's Photo Gallery
I had the same problem. The harness from the car to the factory radio has a wire for the dash lights that shows up as ground with the light off. When the lights are on the wire is 12V+. Check to see if you connected the ground from the new stereo to this wire. The radio will work perfect but everytime you turn thr park light on the fuse will blow...and the radio will continue to work. There should be a ground wire in the harness as well, ensure you connect the ground from the new stereo to this wire.
This worked for me...I hope this helps.
2000 Toyota Corolla 4wd L Touring Wagon (AE104 with 4A-FE)
l_touring_dude is offline   Reply With Quote
Old 02-21-2006, 01:31 AM   #6 (permalink)
Komet's Avatar
View Komet's Photo Gallery
same case with my corolla. But only lights at the air-cond cotroller. Is it due to fuse or some wires not connected?
Komet is offline   Reply With Quote
Old 05-11-2006, 12:37 PM   #7 (permalink)
View Stan873's Photo Gallery
is this a big problem with corollas? my ex's 92 did that and my new girlfriends 95 does too. but the tails are only out when the lights are on. dash lights are totally out too. but ill look into the relays under the hood!
Stan873 is offline   Reply With Quote
Old 07-02-2008, 12:26 PM   #8 (permalink)
View IwuvHimx666's Photo Gallery
i have this same problem did you get yorus fixed?
IwuvHimx666 is offline   Reply With Quote
Old 12-27-2008, 05:32 PM   #9 (permalink)
View Corogon's Photo Gallery
Hey guys I have a 2002 jdm corolla wagon. I switched the original clock for one that has a tach. It actually came from a. AE 100. My car uses coil pack instead of a distibutor, my problem is the tachometer does not work after rewiring. How do I FIX THIS FOR THE TACH TO WORK.
Corogon is offline   Reply With Quote
Old 08-29-2010, 12:30 AM   #10 (permalink)
View coppershot15's Photo Gallery
Hey,
I only signed up for this site because the info on dash lights being out... it helped me fix my 1996 Previa in which I changed the stereo out.. and the dash lights would not come on, but when I tested them there was power, I couldn't figure it out till I read this sites helpful threads. Thank you so much for the HELP. Never would have thought to check the harnness connections for a lead to power up when I switch on the park lights.... THANK YOU AGAIN I_touring_dude for the help!!!
coppershot15 is offline   Reply With Quote
Old 08-29-2010, 10:17 AM   #11 (permalink)
View musclecar64's Photo Gallery
I think this is probably the most common issue I've seen with our corollas. Check the wiring for your stereo harness. There are two orange wires, one is dimmer, one is dimmer ground. These should NOT be connected. Cut them and tape the ends off. If you did wire these together, you probably fried the dimmer rheostat, in which case your lights won't come on unless you replace this. Check the resistance on the rheostat. You also may or may not need to replace your radio/cig outlet or other fuses. Get the rheostat at a junkyard for like $15 and save yourself about $150 over toyota
Edit: oops, didn't realize this was a really old thread.
musclecar64 is offline   Reply With Quote
Old 08-29-2010, 06:54 PM   #12 (permalink)
96 Toyota Corolla
kickfli12's Avatar
View kickfli12's Photo Gallery
i had this happen to me and my tail light fuse was blown. i replaced it and all was good =)
kickfli12 is offline   Reply With Quote
Lights out on Dash after Radio Install ThumpnHighlandr 1st Generation (2001–2007) 1 04-06-2006 03:34 PM
dash lights svtmustang07 Audio, Video, and Security - Tech 1 05-13-2005 07:49 PM
What Do These Lights Mean?, ECT and a little dash light... ArmyofOne Camry & Solara Lounge 10 09-30-2004 02:30 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 02:38 AM
My Dash lights are OUT! ineedhelp Hardcore Tech and Competition 6 07-22-2003 03:10 PM
