Instrument cluster 94 swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2006, 01:51 PM   #1 (permalink)
View motu 56's Photo Gallery
My 94 GEO prizm has the standard instrument cluster can I swap it out with an instrument cluster thaat has a tach?
motu 56 is offline   Reply With Quote
Old 04-26-2006, 04:35 PM   #2 (permalink)
View lifeisviewtiful's Photo Gallery
yep, just get one with a tach and wire it up. don't know if the tach wire is there or not, but it goes right in there.
lifeisviewtiful is offline   Reply With Quote
Old 05-06-2006, 09:21 PM   #3 (permalink)
AE95 wagon carib/corrolla
cuzman's Avatar
View cuzman's Photo Gallery
the wires are ther just plug it in !!!!!!
AE95 Constant 4wd Wagon(carib) 20v silver top 175hp
http://spaces.msn.com/cuz1
cuzman is offline   Reply With Quote
Old 03-17-2008, 12:52 AM   #4 (permalink)
View markdemo's Photo Gallery
hi i tried to do the same it all fits but every thing is all ass about open the door the brake light comes on instead of the door light,temp and flue light works back to front so be careful
markdemo is offline   Reply With Quote
Old 03-17-2008, 01:26 AM   #5 (permalink)
cuzman's Avatar
?what dash
If you update a std dash insert to a tacho dash you need to move about two wires which i canot remember. you will need to follow the copper lines on back of the dash to work out which pug or wire does what, then just cut the wire for eg the door light on the dash loom and wire it to the appropriate dash light.
If you want to use the gt or sx dash it is possible but a pain in the ass as you need to almost rewire every plug and find another solid rear plastic mount to the dash, i used a camery one on my second dash upgrade.
depending on were the car and or the dash is made for like japan or europe etc there are small variations to upset us!
If when you open the door another light comes on switch wires etc until you hit a home run
good luck.
Will a 4cyl instrument cluster work on a 6cyl? newbie212 Camry & Solara Lounge 7 02-11-2006 11:55 PM
Help with instrument cluster! Crazy-Horse Archived Corolla threads 7 01-12-2006 08:38 PM
Bright white gen3 camry instrument gauge cluster w/pics gen3guy 3rd & 4th Generation (1992–1996 & 1997–2001) 9 05-25-2005 12:37 AM
Gauge Cluster Swap cheeba Camry & Solara Lounge 3 10-24-2003 04:28 PM
GEN5 instrument cluster question mach_y 5th & 6th Generation (2002-2006 & 2007-2011) 17 08-18-2002 11:23 AM
