Hi, I have a 1993 Corolla clone (Geo Prizm) with a 1.8L motor and a 5 speed manual transmission. How much of this gear oil am I going to need to drain/replace the fluid in the transfer case? Thanks
Only use the numbers as a guide though, the proper procedure (on flat ground) is to fill the transmission until the oil is level with the fill plug opening.
Also remember to ALWAYS take the fill plug off first before removing the drain plug. Nothing worse than draining the old oil only to strip the fill plug and be unable to re-fill.....
