Gear oil question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-16-2007, 02:58 PM   #1 (permalink)
View canadiancelica's Photo Gallery
Gear oil question
I didn't get a book with my 97 rolla sd and Im curious as to what weight gear oil the gearbox calls for and if there are any synthetics that can be used.
I know in my celica it was recommended to use semi synthetic gm friction modified synchromesh.
Thanx all
canadiancelica is offline   Reply With Quote
Old 02-16-2007, 04:13 PM   #2 (permalink)
Never mind, got it. Amsoil 75W90 GL-5 it is!!
Old 02-16-2007, 08:57 PM   #3 (permalink)
View 94_Rolla_Guy's Photo Gallery
may want to stay away from GL-5 fluid and any fluid with limited slip additive the GL-5 can be corrosive to soft metal parts in GL-4 aplications and the limited slip can also cause issues due to the fricition modifiers,
I have tried alot of different fluids and my favorite is redline MT-90
http://www.redlineoil.com/products_g...7&categoryID=7
Next time im gonna try MTL because its a little thinner and supposedly may help smooth out the shifting even more.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 02-16-2007, 10:21 PM   #4 (permalink)
Book says GL-4 and GL-5
But, hmmmmm, still something to think about though.
thanx mang
Old 02-17-2007, 12:07 AM   #5 (permalink)
Moderator
Gameroom cash: $493137
View silver04rollas's Photo Gallery
Redline MT-90 (type GL4 with a higher viscosity than GL5) is what I use. I highly recommend it since both upshifts and downshifts become super smooth. On freezing cold days, I do not have to wait for the car to warm up so that I can get the car into gear. It shifts like butter even when the car is cold.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/H&R Racing/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
Old 02-17-2007, 08:36 AM   #6 (permalink)
Yeah, sounds like GL-4 is the way to go then.
Redline MTL is GL-5. Both sites state that the friction modifiers have been removed and it makes it great for cold days and racing. But It makes me think "too thin"..
Think I'll stick with a GL-4 fuid, amsoil or redline, whichever is readily available here.
thanx fellas
Old 02-17-2007, 11:59 AM   #7 (permalink)
wantin150's Avatar
View wantin150's Photo Gallery
Modern GL5 gear oils are not corrosive to soft metals any more. They were. A car spec'd for GL4 or GL5 will work with either fluid. HOWEVER, using a GL5 can usually cause more difficult shifting unless you're in an area that is always warm. It did in my 03 Matrix 6 speed. You can't go wrong with the good GL4's mentioned. I finally settled on Redline MT90 in both my Matrix and my 04 5 speed Tacoma after having tried the Amsoil MTG GL4 75W90 and their SVG GL5 in the Matrix. Good all around shifting with the MT90. The Tacoma is a little notchy when cold but that goes away once the fluid warms.
2003 XRS - Indigo Ink Pearl
K&N Typhoon SR
Magnaflow Cat back Exhaust
Energy Suspension Motor Mounts
Speed Source Cable / Shifter Base Bushings
wantin150 is offline   Reply With Quote
Old 11-09-2007, 02:02 PM   #8 (permalink)
View Rassig's Photo Gallery
Originally Posted by wantin150 View Post
Modern GL5 gear oils are not corrosive to soft metals any more. A car spec'd for GL4 or GL5 will work with either fluid.
There are PLENTY of GL-5 gear oils that have sulphuric-based additives that are indeed corrosive to brass & copper.
I know the VW 020 trans has brass synchros,
and VW trans gurus find that using a GL-5 in the 020 trans will shorten synchro life by aprox 50%.
However, I don't know about the trans in my g/f's '92 Corolla.
You are correct, sir. Better to play it safe.
GL-5 is not always a good substitute for GL-4...
You are in error, sir. MTL is GL-4.
BTW, MTL made a huge difference in my '86 VW GTI.
Smooth shifting in all temps.... like butta!
Rassig is offline   Reply With Quote
Old 11-09-2007, 02:11 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
I'm using castrol EP80... I dont think its that good.. might change the stuff when I change my clutch.
Old 11-30-2007, 07:34 AM   #10 (permalink)
View aarong420's Photo Gallery
I can never seem to get the rite amount of gear oil in the box. Either put too much or too little.
Does anyone know the required amount of oil to put in a C52 20v 5fwd gearbox? Is there a level mark somewhere on the VSS or sumthing?
aarong420 is offline   Reply With Quote
Old 11-30-2007, 10:01 AM   #11 (permalink)
I don't know, but:
-call a Toyota dealer & ask for the official specs.
-Google is your friend
-on every car I ever R & R'ed the gear oil, there's never been a level mark or anything.
The usual routine is fill it up until it flows out of the "fill hole".
However, if you are filling it up through the speedo hole, it will be helpful know the exact specs.
Overfilling by a bit shouldn't create any problems, though...
and is certainly better than underfilling.
Old 11-30-2007, 10:59 AM   #12 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
you just fill it at the fill plug until it reaches the hole, then put the plug back in.. that is just about in every manual trans, transaxle, differential...
retiredat44 is offline   Reply With Quote
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 10:00 AM
'05 Taco Speed/RPM charts Sonny 2nd Generation (2005+) 4 03-11-2007 02:08 PM
Please Help Me With Gear Switching baller Archived Corolla threads 28 10-10-2006 02:45 AM
Oil light problem and CV joints question Akuma Tercel, Paseo, Starlet, and Sera Forum 4 03-13-2006 11:59 AM
Oil filter Question (want to go bigger) EuroCamz Camry & Solara Lounge 26 05-30-2004 01:53 AM
