97 Corolla Insufficient EGR? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2007, 09:01 AM   #1 (permalink)
View gobraphil's Photo Gallery
I have a 97 1.8 that is throwing an insufficient EGR flow Check Engine Light. My question is this, Can this be caused by a vacuum leak?
I pulled off the intake manifold to fix a burned starter wire and the problem surfaced soon after.
Other symptoms include:
High idle when cold outside
Trans wont shift into 4th until warmed up
Any ideas? Im thinking it is a vacuum leak but i cant find it.
Thanks in advance.
gobraphil is offline   Reply With Quote
Old 04-02-2007, 10:05 AM   #2 (permalink)
View TRCar54's Photo Gallery
it's probably the EGR modulator valve. It's pretty easy to check. Each port should hold a vacuum. If not, the diaphragm inside has split.
TRCar54 is offline   Reply With Quote
Old 04-02-2007, 09:13 PM   #3 (permalink)
Thanks for the reply. Would the vacuum leak in hte modulator cause the trans shifting problem?
Old 04-03-2007, 07:09 AM   #4 (permalink)
You're welcome.
If you have an overdrive automatic (4 speed), the transmission should not shift into 4th (OD) until it has warmed a bit. Mine usually shifts into 4th when the temp comes about 1/4" off cold.
Old 04-03-2007, 07:13 AM   #5 (permalink)
OK, thanks again. I just ASSuMEd it was related to the other problem i had. I will try to test the regulator this weekend. I have bookmarked the articles on here that mention the procedure to test it. It hasnt made sense yet but it will once i look at the egr setup on the car again.
Old 04-03-2007, 09:04 AM   #6 (permalink)
Here's a link where we discussed the problem in detail.
Good luck
http://www.corolland.com/forums/inde...3&hl=modulator
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 06:19 PM
93 - 97 corolla ? RogueSeo Archived Corolla threads 2 12-03-2006 01:58 AM
Minor questions about the 97 corolla. Driver Archived Corolla threads 6 07-31-2006 11:14 AM
'97 corolla having trouble starting after rain Ranger X Archived Corolla threads 4 07-24-2006 01:44 AM
