Ok i need to chime in on this...... don't feel like typing so im gonna cut and paste all my "input" from all the other posts i can find that i wrote...
i wanna add something here, with the 93-95 1.8L oil burning (7A-FE) your not alone i think every single 93-95 1.8L burns oil, i replaced my engine with a low KM engine and its right back to its old tricks burning 1L every 750 - 1000 Km's
If i were you i would do 1 of 2 things:
1. Buy a used engine from a 96 or 97 they are better and seem to have fewer problems..but you will have to transfer all sensors & distributor from the old engine over and remove the EGR valve and block the ports. The problem is it could still burn the later engines are better but not exempt from bad rings
2. Haul the engine out of there and have the bottom end rebuilt with oversized pistons, new rings, bearings the whole bit. you can probably just reuse the head without any work being done. (to me this is the better bet the engine will be like new and last a good life)
BTW if you buy an engine with problems there gonna wanna see it running with the problems then expect the engine returned for a exchange. I personally went through this and got fucked so bad my ass still hurts...
___________________________________________
well im looking at around 1200 CDN for just the rebuild (parts, machine work, labour) for you it would cost a little more for removal and re-installation. Go find a few engine re-builders in your area and see what they say price wise...
BTW the engines will run forever evem burning like 1quart every 500-600 miles. The reason im even gonna bother is because where i live we have Emmission testing and mines not gonna pass this time around..
not an uncommon issue at all i bet your going through about a litre every 1000Km?? maybe a little less... any ways i wont get into it to deeply, id put my money on the oil control rings being worn/stuck in there grooves... basically your looking at a short block engine rebuild... the good news is even though its burning, it will last a good long time, LONG AS you keep the oil no more than 1/2 a litre (or half the fill portion on the dipstick) down as lower can cause momentary loss of oil pressure causing bearing damage....
its not so much a wear problem with the rings they sludge up get stuck and the drain holes in the ring grove plug, and the oil cant be controlled by the rings (stuck) and has no where to go thus it blows by the compression rings.
with your oil burning the dealer is right i would bet $1000 its the piston rings, specifically the oil control rings stuck in there grooves. If you search on here you will find many 93-97 owners and 98-02 members with similar problems...
I have some expirience from my 94 and its consumption issues i will sum it up
Castrol GTX seems to have the least burn off
- you can use 10W-40 but i would NOT use anything heavier IE 20W-50
- Flushes or cleaning products don't seem to do anything some make the consumption worse
- The engine will last quite a while burning oil, provided you keep oil in it
- Keep the oil level no lower than halfway down between the Low and High marks, lower and you can get drops in oil pressure that can damage the bearings
- Do the oil changes consistantly don't neglect oil changes or your oil consumtion will most likely get worse
- The compression results will be high like you said, a leak down won't find anything either..
Hello, Im in the same boat almost identical to schn0354, started doing it when i bought it at 125k replaced the engine with a low km used one at 214 KM ,same bullshit all over started at 1L every 3000 now at 246 KM its at 1L every 1000 KM using 15w-40 diesel oil.
Im getting ready to do something, haven't decided if im gonna go 4A-GE or rebuilt the smoke factory.
I have gone into it a little more, its all the oil control rings, nothing more, on my old original engine upon removal the rings were hopelessly stuck in there grooves, nothing i found would un-stick them. after removing the scraper rings they have no spring, but still maintain the proper end gap suggesting they haven't worn at all.
I have the same bald spot on the thrust side of the bore but unfortunately my engine is about .0005" over tolerance before honing so like .0010" after, besides that the piston skirts have moderate scoring so it doesn't make sense to reuse the pistons. The crankshaft has scouring because of oil starvation because of low oil...
Gotta start a 7A-FE Oil burning fan club..... theres alot of people out there!
the compression will most likely come out perfect even above perfect my 202km engine was doing 215psi but after taken apart and looked at the compression rings were completely free and minimally worn BUT the oil rings were hopelessly stuck level with the skirt but surpriseingly not badly worn. i put the pistons in varsol, acetone, clean oil and it took weeks for anything to happen. that motor was hopeless burning 1liter every 250-500km now my supposed "low miler" is burning 1Liter every 1250-2000k so i have been messing around trying to desludge it before im replacing bits.
From being around the corolla's a bit ive seen alot of the 93-95's (7A-FE) that burn oil but i do know and see a few people with the 4A-FE and oil issues later in 95-97 OBD2 and some minor changes seem to address and correct the issues a bit?!?!?! as the problems seem to be less.
If you want somemore reading try
www.bobistheoilguy.com and check out the forum
Hello welcome to the oil burning family, less common on the 1ZZ-FE but still a problem, the majority of the problems reside on the 7A-FE (93-97 corolla 1.8L) just search "7A-FE oil burning" or similar stuff
Over the two different engines i have had in my car both have burned oil.. I have played around and found that some oils burn less (castrol GTX 10W-40) and castrol products in general seem to work well. i have tried a few different flushes and treatments with next to no luck most of the time the treatments increase the consuption.
My advice is let it warm up a little like until the temp gauge reads something, run it gently until up to temp, keep the oil no more than 1/2 a quart down, more can cause unstable oil pressure hence engine damage.
do this and you should see the consumption go down and become a little more manageable
The high HC's are caused by excess fuel or incomplete burn... if by chance the engines burning oil thats most likely the cause. If it hasn't had plugs in a while thats not a bad thing to do also clean the throttle body and tune-up stuff, now ive never heard of xylene, but i have heard of the methyl hydrate or gas line antifreeze aproach, also if its high on HC and you don't care about whats causing it try advancing the timming like 2 deg, that will lean out the engine, just be careful in doing so...not to lean it out too much keep an ear out for pinging...also to much lean out and it will fail on NoX
