EGR problem 1995 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2007, 10:20 PM   #1 (permalink)
View ksorce's Photo Gallery
I'm diagnosing an EGR problem on a 1995 Corolla with the 1.8 engine. I got a 71 code but also even with the cel cleared the car failed NY inspection for NOX levels. I applied vacuum directly to the EGR with the car idling and it dies so that tells me the EGR is not stuck. I was trying to t-shoot the modulator and VSV. The question I have is at what particular speed should I feel vacuum from the R port on the throttle body? It does not seem to be giving any vacuum at any engine speed. I also opened the throttle with the eigine off and can't blow air into the vacuum fitting for the R port on the TB nor spray carb cleaner through it. This makes me think it is plugged but I'm not sure if this is a condition of how the R port is supposed to work. Help!
ksorce is offline   Reply With Quote
Old 08-23-2007, 12:58 AM   #2 (permalink)
View dandxg's Photo Gallery
I had similar problems in my 96, kept replacing parts on check engine. It took a new O2 sensor, egr valve, and vsv. Consider spending 50-75 bucks to have the dealer diagnose and then fix yourself. They can find the problems in 30 minutes or less with their 100k plus computer.
dandxg is offline   Reply With Quote
Old 08-24-2007, 12:26 PM   #3 (permalink)
Still need question answered about R port on TB for EGR!
All, view my original post. I'm just wondering if anyone knows about how much vacuum and at what throttle position I should be receiving vacuum off the TB at the connection for the R port going to the EGR modulator. Thanks
Old 10-16-2007, 01:14 AM   #4 (permalink)
View GTSTWINCAM's Photo Gallery
let me know if you fixed your CEL code 71. I have the same problem.
1991 Toyota Celica GT-S 5SFE
1995 Nissan 240SX SE KA24DE
2000 Nissan Primera SR20DE
GTSTWINCAM@yahoo.com
GTSTWINCAM is offline   Reply With Quote
No EGR Valve in my 94 Corolla??? navalfan Archived Corolla threads 6 12-08-2010 04:49 PM
Corolla 2002 bogging problem jojos Archived Corolla threads 7 08-02-2005 08:23 AM
Corolla 91' Problem faisal Archived Corolla threads 4 02-25-2004 03:31 PM
vacuum sucks! 1995 4afe problem madalo Archived Corolla threads 4 02-08-2004 02:49 AM
