93 corolla computer - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2007, 07:10 AM   #1 (permalink)
View repairman's Photo Gallery
93 corolla computer
was wondering if anyone can tell me where the computer is located so i can take it out for a swap. I need the serial number off it to compare since there are so many models. Had it to a mech and this is solution he came up with. Starts fine cold but once warmed up will not start, too much fuel, injectors tested fine , fuel pressure fine, all sensors test fine???? Idels high when it runs also. thanks
repairman is offline   Reply With Quote
Old 09-26-2007, 10:34 AM   #2 (permalink)
View tashirosgt's Photo Gallery
On my '90 there is a panel on the right side of the drivers right foot and the computer is behind it. So it's down below the radio and in front of the console that has the shifter.
tashirosgt is offline   Reply With Quote
Old 09-26-2007, 12:08 PM   #3 (permalink)
View freebeer's Photo Gallery
If you mean the ECU, it is in the center behind and beneath the radio-heater-ashtray section of the console. Be prepared to remove a LOT of the lower dashboard stuff to get to it. You can probably see the side of it now, it's the silver box just aove the carpet next to the gas pedal. About 2 hours worth of work to get at it, just be careful with the plastic parts as they break fairly easily.
freebeer is offline   Reply With Quote
Old 09-26-2007, 02:24 PM   #4 (permalink)
Gameroom cash: $147537
Could be dying ignition coil. You sure you have spark when starting warm? If the car runs, there is nothing wrong with the ECU.
Old 09-26-2007, 03:10 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
or the ignition module (more likely than the coil)
93 Corolla - Replacement Parts??? kids_corolla Archived Corolla threads 4 10-11-2005 10:22 PM
A few issues with my '93 Corolla. Klinky Archived Corolla threads 2 02-15-2005 09:09 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
want to buy brake pads for 93 corolla BMtak Archived Corolla threads 7 05-29-2004 11:31 AM
93 corolla question gf has a camry Archived Corolla threads 1 07-11-2003 03:35 PM
