Brake Kits? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2007, 01:01 PM   #1 (permalink)
Holding Off 20th AE GTI's
94DX5Speed's Avatar
View 94DX5Speed's Photo Gallery
USA Brake Kits?
I have a '94 Corolla DX, my pads, shoes rotors, etc. are fine, but they just don't seem to be giving me the braking power I need. Are there any brake kits for the Corolla? Also, if I push the pedal a couple of CM down when I'm driving it doesn't seem to brake until I push down a bit more and then the brakes come on. Could this be the cause of faulty brake lines? Thanks for any help.
1994 Corolla DX 5-Speed with tachometer, working A/C, and a casette player. Everything I need.
*RIP* 11-19-07
Reborn 12-08-07
94DX5Speed is offline   Reply With Quote
Old 09-26-2007, 01:44 PM   #2 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $120200
View Piloter's Photo Gallery
Hit up Tire Rack for some quality rotors (blank versus slotted versus drilled is a choice you'll have to make for yourself and do some research), ceramic pads, and stainless-braided lines. That should make a difference.
WIP AE102.
Piloter is offline   Reply With Quote
Old 09-26-2007, 01:51 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
If he has a fault in the braking system, I'd say take care of that first. Corolla brakes are actually good enough, I've tracked a corolla with stock brakes and it didnt cause any issues.
Old 09-26-2007, 02:44 PM   #4 (permalink)
blb
View blb's Photo Gallery
Make sure the self adjusters on the rear brakes are working properly. Manually adjust the rear brakes until the shoes are just slightly touching the drum by rotating the star wheel. You also may want to bleed the lines to make sure there is no air in them. (Air is much more compressable than brake fluid). In addition, make sure the sliders on the front calipers move freely and none are frozen in place.
blb is offline   Reply With Quote
94 Camry brake warning light eaglemtn 3rd & 4th Generation (1992–1996 & 1997–2001) 24 09-16-2011 06:07 PM
3rd brake light fuse popping gameguru1360 Archived Corolla threads 4 03-15-2007 04:21 PM
gen2 brake light stays on... help... please.. busted_ride 1st & 2nd Generation (1983–1986 & 1987-1991) 2 09-24-2004 05:56 AM
