I think I just found out.
When I had the tires replaced, the mechanic told me there was a lot of play on the side with the brake problem, and he would suspect the bottom ball joints. Seeing it myself was enough for me to grab a pair of ball joints to replace them. I jacked that side up, prepared for the task, an noticed the HUB was wiggling, not the braket.
After taking it apart and cleaning it, I think I can piece it together.
Before I bought it, The previous owners had the clutch replaced. Apon completing the job, The mechanic must have neglected to tourqe the shaft nut on there (On BOTH of them; I replaced the other driveshaft a few weeks earlier, and noticed the nut was too easy to get off) , so the hub was sitting loose.
As it drove on, the inner inside bearing race came loose, and the hub wore on that race. When the shaft under the race was a smaller diameter, the hub started to angle up, and that included the brake disc...
So, It WAS the wheel bearing! I need at least a hub. Are there aftermarket ones available, or am I stuck at Toyota's high OEM prices?
