Turbo kits for AE101 96 Rolla - Page 5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2007, 12:08 PM   #61 (permalink)
7th Gen Apprentice
View costadragon220's Photo Gallery
Originally Posted by Piloter View Post
Importperformanceparts.net has a wide variety of stuff that would be useful--you can get the manifolds from the Turbo Specialties kits separately, for example.
As for what turbos would work best with the 7AFE, I've been doing /extensive/ modeling with compressor maps, flow calculation spreadsheets, and Engine Analyzer Pro...although it's for the 7AGE, the same general conclusions should apply. For good reliable ~6 PSI boost by ~2600 RPMs, the GT2560R works nicely, as does the TD05-14B, these are dirt-common turbos in junkyards etc. The T3 Super 60 has higher potential but doesn't see full half-bar boost until 4,000+ RPMs. The engines also respond well (theoretically) to the Eaton M62 blower. As soon as I can dig up some figures on the T3/T4 hybrids, I'll probably simulate those. If anybody's interested in the spreadsheets with flow calcs, I can post those or post a couple simulated dyno runs.
What's with 7AFE Talk? This is for 4AFE. But thanks for the info
Will the same apply for 4AFE ,you think?
costadragon220 is offline   Reply With Quote
Old 10-16-2007, 05:47 PM   #62 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
More or less. F-head early spooling should probably compensate for the .2L difference that would lead to later spooling.
WIP AE102.
Piloter is offline   Reply With Quote
Old 10-16-2007, 06:32 PM   #63 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
F-head early spooling.. what what what?
Old 10-16-2007, 07:57 PM   #64 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
View jmaz87's Photo Gallery
the FE head has narrow-angle ports witch are supposed to create slightly more low-end torque but with the sacrifice of horse power... basically there is less of a gap between the two but that doesn't make it faster and you can't upgrade FE internals...
basically the FE head can't handle as much boost as the GE but will respond better at low-boost due to quicker spooling and torquier throttle-response. at least that was what i could gather
that is why for now i'm leaving the wastegate at 8psi and eventually if i have problems i'll probably grab a GZE for the convenience of american parts or maybe silvertop
Finally welded an inline turbo tube and brought my SRI down to the driverside front lip Yeah baby True-CAI i'm move the blinkers and open the bumper up next...
can anyone get me the the euro or jdm bumper that doesn't have 30lbs of fucking steel( to uhhh protect us)... in the middle other wise i'm pulling out the Saw Zaw!!!
85' AW11 - DD/light track duty
87 AW11 - Restoration Project
88' FJ 62 - My Baby
90' AE92 - Spare Shell
91' AE92 - DX - GTS
91' AE92 - Grocery Getter
jmaz87 is offline   Reply With Quote
Old 10-17-2007, 12:51 AM   #65 (permalink)
Resident asshole
Flashmn's Avatar
I didnt ask what the F-head is like, I know it pretty darn well.. I've never heard of it spooling something faster. It does resist knock better.
Old 10-17-2007, 06:23 AM   #66 (permalink)
KhmerXboyXnoy
ae92Xtruen0Xsr5's Avatar
View ae92Xtruen0Xsr5's Photo Gallery
when it comes to spooling it all has to do with the turbo, what it is and usually how big it is. like flash said i dont think the head has anyhing to do with making it faster?
I am a fat man...With fat dreams...How far will you go yo?...
89'Ae92 Sr5 corolla...4Af Carbed...
93'EG civic coupe...D16z6 V-tec
ae92Xtruen0Xsr5 is offline   Reply With Quote
Old 10-17-2007, 08:51 AM   #67 (permalink)
7AFTE's are fun
trancedcorolla's Avatar
View trancedcorolla's Photo Gallery
With a t25bb (t25r is what they call it now), mine spools at about 2,100 ish.
trancedcorolla is offline   Reply With Quote
Old 10-17-2007, 09:34 PM   #68 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
it has to do with the relationship between the impeller size and the amount of flow ie size of header/motor...
last time i checked the EXHAUST ports were different than the GE and therefore would change the FLOW witch may or may not affect SPOOLING
I'm not arguing witch is better or spools sooner i was just clarifying what MIGHT cause the FE to spool faster.
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 11-02-2007, 01:34 PM   #69 (permalink)
View JoeAE101's Photo Gallery
The 4AFE can be upgraded, it'll set you back a couple of $$$$$. For instance the pistons can be swaped with some old (I stand corrected) mr2 ones. The cams can be custom built. The engine top can be cut. Anyways..... The most important thing is the ECU for N/A or Turbocharged engines.
JoeAE101 is offline   Reply With Quote
Old 11-03-2007, 09:46 AM   #70 (permalink)
AE92DX 4AFTE
jmaz87's Avatar
any standalone recommendations? my honda friend is good with mega-squirt and said he'd help set it up after i turbo...
88' FJ 62 - My Baby
91' AE92 - DX - GTS
Old 11-03-2007, 10:15 AM   #71 (permalink)
Resident asshole
Flashmn's Avatar
Mega-squirt is cheap... but.. it has alot of limitations, newer versions such as the VEMS one are getting better.. I didnt have luck with it so I went with Van Kronenburg management systems (KMS)
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
Any turbo kits available for MK1 MR2's?? toyloco MR2 Forum 1 02-06-2006 07:13 AM
Need Pricing on a 96 'Rolla SirLazarues Archived Corolla threads 1 09-30-2004 04:48 PM
Custom turbo project for 98 rolla rollatuner110 Archived Corolla threads 2 06-02-2004 10:45 PM
Headlight probs. and others 96 rolla DX corollaNY Archived Corolla threads 3 09-18-2003 09:24 PM
