The A/C in my 93 Corolla has stopped working properly.
It appears the the compressor does not come on when I press the A/C button. I have checked relays and fuses.
I am not certain, but it appears that the R12 is low (or gone).I do not see any R12 in the sight glass, but I am told that unless the compressor is on, you will not see it.
I was inspecting the compressor and switches this morning.
I found a loose wire between the compressor and the alternator. The wire is yellow and has a small female connector on the end.
I am not sure where the wire goes.
This could be the reason the compressor is not running.
Any ideas where to plug it back in? What does this wire do?
Here is a picture of the wire.
http://sears572.com/albums/album11/C...wire.sized.jpg
Thanks for any information.
