triple belts (fan) 1.8 l 95 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2007, 09:02 AM   #1 (permalink)
geoski's Avatar
View geoski's Photo Gallery
Hi I have a low mileage for its age 95 corolla wagon with a 1.8
engine.
The belts that go around the alternator , waterpump and air
conditioning are seperate in this years model.
I want to change all 3 of them --yes 3 (three) of them..
Can someone tell me which bolts need to be removed and were they are
for each of the 3 belts ?
This would be a big help -- and pics even more
(they did not use a serp belt till the 98 ? models came out)
manys thanks -- no pics in the chilton or haynes manuals
I've never worked on a toyota before
geoski is offline   Reply With Quote
Old 10-04-2007, 12:08 PM   #2 (permalink)
View 94_Rolla_Guy's Photo Gallery
for the alternator belt you loosen the alternator, there are two bolts one to lock it down and one that pulls the belt tight they are hidden on the underside of the alternator and are a bitch to get at
for the A/C belt just under the alternator attached to the engine block there is another tensioner setup similar to the alternator, one bolt to tighten the belt and another nut to lock down the pulley
Power steering you have to loosen the pivot bolt down the back of the engine at the base of the pump, then there is a lock bolt at the back between the pump and the firewall it rides in a slot, BTW you will need a pipe or prybar to tension the belt.
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 06:19 PM
95 Corolla Idling Young James Archived Corolla threads 2 04-13-2007 12:33 AM
New Member - 95 Corolla Young James Archived Corolla threads 6 03-14-2007 09:39 AM
WTB: 88-92 Corolla Radiator Fan ghost_ryder35 Car parts for trade or wanted parts 4 01-04-2007 11:06 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
