94 Prizm 4FAE hesitation
94 Prizm 4FAE, 1.6L, AT, AC, 114K --bought it used (clean car). Rough at idle and spark knock -- not running real smooth. Replaced: Ign wires, plugs, cap, rotor, air and fuel filters.... timing belt (kinda big job but I've done it before on other vehicles). Still runs the same. Checked timing-- and it was @25deg -- way off. Re-set timing to 10 deg per the specs --now idles very smooth -- but stutters very bad during acceleration -- not streetable.With timing light connected -- light goes dark during throttle movement(engine stutters) -- then signal resumes when throttle stationary at any position. Same condition at all 4 wires. Not getting any OBD1 codes. I can usually fix about anything, but this has me baffled. Appreciate any thoughts......
