I can help you with the ceiling light.
First check the fuse, then check the bulb, if neither of those are broken or bad, then with the ceiling light OFF, unscrew it from the car. I had 2 screws.
Then it should fall down, but get caught by the wiring assembly still attached. Unattach only with the light OFF! No taking risks, no matter how small.
Inspect the thing, chekc the terminals on front where you select what light you want on.
If it is green/white, it is corroded. Scrap off the corrosion, use a bit of coca-cola as well that will help. That is like cleaning a battery terminal, the contact points have corrosion so they don't actually touch.
If that does not help, or there was no corrosion, then while the light is connected to the wiring harness and OFF, use a voltmeter thingy, try to find out where the current stops.
If that doesn't help, and you get really mad at it, try to find a replacement one at a u-pull, beware of corrosion though.
