93 prizm speedo problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 09:06 AM   #1 (permalink)
View mejose's Photo Gallery
my speedo and odom don't work below about 60 mph. Any ideas would be appreciated.
thanks
mejose is offline   Reply With Quote
Old 10-15-2007, 09:25 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Do you mean that they give the wrong speed and mileage below 60 or that they don't turn at all?
tashirosgt is offline   Reply With Quote
Old 10-15-2007, 10:00 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
must have an electronic sensor,,,. which means some electrical part is bad...
retiredat44 is offline   Reply With Quote
Old 10-15-2007, 10:16 AM   #4 (permalink)
Here is the true scoop (my daughter's car). The odometer does not work at all, the speedo stays at zero until roughly 30-40 mph then jumps to 65 or so and stays there until you drop back down to somewhere below 30 then drops to zero and stays.
thanks folks.
Old 10-15-2007, 11:03 AM   #5 (permalink)
Exclamation
a kinked cable can do funny things, but I thought the Corollas older than 91 or 92 had electronic speedo?
Old 05-22-2008, 01:52 AM   #6 (permalink)
View flinardi's Photo Gallery
Did you ever get an answer to your speedo problem? I'm having the same problem. What you described is exactly the same. Th Haynes manual as well as my local mechanic said to replace the speed sensor. I replaced the sensor and the speedo is doing the same thing.
flinardi is offline   Reply With Quote
Old 05-22-2008, 08:19 AM   #7 (permalink)
Bitter's Avatar
Gameroom cash: $485950
View Bitter's Photo Gallery
i'd go after the gauge, if the spring inside has broken it can do funny things like that.
Old 05-22-2008, 09:14 AM   #8 (permalink)
No, I haven't resolved the problem yet. I purchased a used shop service manual just for that year Prizm. With the trouble shooting I did I am 99% sure it is the speedo head. The quote I got was $165, ouch! Still haven't sprung for that yet.
Please folllow up this post if you fix it.
Thanks.
HELP!! idle problem on 93 corolla xevox 7th Generation (1993-1997) 2 11-21-2008 08:17 PM
Strange Stalling Problem on 93 Camry 4cyl - Please Advise MSgtVac 3rd & 4th Generation (1992–1996 & 1997–2001) 35 11-02-2008 02:26 PM
97 Geo Prizm 1.6 Problem ben_g99 Archived Corolla threads 4 08-09-2005 12:10 PM
