alt or battery? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2007, 01:38 PM   #1 (permalink)
View sdbct1's Photo Gallery
alt or battery?
Hi gang,
OK here's the problem. When I step on the brakes, close the windows, andthing that requires power my lights dim. At a stop light I idle rough, lights flicker. Is this my alternator, which is origonal, or my battery? Also org. Its a 1997 if I didn't say. Is there something else I should check as well? I'm going long distance in a couple of weeks, don't need to get stuck.
Thanks,
Matt
sdbct1 is offline   Reply With Quote
Old 10-20-2007, 02:18 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check battery voltage after it has rested (say overnight) should be about 12.6-12.8V.
Start the car and run at about 2000 RPM with all electrical items off, check voltage at the battery terminals (now with alternator working). Should be around 14-15V.
Increase the load on the alternator by turning on the headlights, heater fan, stepping on brakes. Check voltage again at the same RPM, it should be the same. If it dropped the alternator has a problem.
Also clean the battery terminals. Auto Zone and other stores can do a batter load test and check the alternator (if out of the car).
Old 10-20-2007, 02:21 PM   #3 (permalink)
joeyicu's Avatar
View joeyicu's Photo Gallery
if your alternator was bad your battery light would come on
batteries can become weak, but if the car cranks over nicely and fires up fine then i wouldnt worry about it
my car with the lights on, on the highway at revs, when i roll up windows makes my lights flicker, these alternators probably dont put out that much amperage, thats all
your miss is something else, and it is a horrible idea to diagnose problems just on gut descions and/or guessing, if you are worried about it and are that unsure i would say take it to somewhere knowledgable and see what they say
-<2001 Chevrolet 2500HD 6.6L 5A 4x4>- 14.6@88mph - Edge Juice Chip, Cut Muffler
-<1990 Nissan 300zx NA 5M 2+0>-
Stillen Catback, Kenwood HU
joeyicu is offline   Reply With Quote
Toyota: Reconditioning Can Extend Hybrid Battery Life Tideland Prius Toyota News 8 10-10-2007 11:28 PM
Battery dies after 3 -4 days capinoy 89-95 Toyota Pickup/Hilux 13 06-05-2007 11:37 PM
Battery Problems haux Camry & Solara Lounge 3 09-21-2006 01:48 AM
More on this damn car battery! speedemn Camry & Solara Lounge 14 01-01-2006 10:21 PM
Battery ?'s 1995 camry V6 LE kenny1773 3rd & 4th Generation (1992–1996 & 1997–2001) 14 11-29-2004 04:29 PM
