1996 Corolla back lights problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2007, 01:17 AM   #1 (permalink)
View bojo09's Photo Gallery
I have a 1996 Corolla Dx which I just bought and there is one problem, the back lights on the car dont work, position lights, brake lights. Also if I turn the light switch to off and press on the brake my interior lights flash every time I step on the brake pedal. Did anyone have this problem, and what should I check first. Thanks
bojo09 is offline   Reply With Quote
Old 10-31-2007, 08:29 AM   #2 (permalink)
blb
View blb's Photo Gallery
Sounds like a bad ground. Check all the ground connections for corrosion and clean and tighten as necessary.
blb is offline   Reply With Quote
Old 10-31-2007, 12:59 PM   #3 (permalink)
View cheesep's Photo Gallery
Yup, I agree about the ground. First though, make sure all your bulbs are good and that you have no blown fuses. If you have a blown fuse, even if it's not directly related to lights, it may affect other circuits. If there are any plugs in the circuit, unplug them and plug them in to make sure there is proper contact. Use a small alligator clip cable to directly ground a light socket and see if it works. If the ground wires are linked together on the tail lights by short pieces of wire connected with philips screws (as in the '91's), loosen the screws slightly and tighten to make sure there is continuity. If you don't have a Haynes manual you can likely find a wiring diagram at www.autozone.com under vehicle repair guides.
cheesep is offline   Reply With Quote
Old 10-31-2007, 01:17 PM   #4 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
that's my big gripe about these cars,, all plastic cars,, when they reach a certain age, the plastic completely goes to shit,, and it's almost impossible for the average person to fix.. the plastic breaks, the cheap metal connectors rot, rust. and break... and you end up with an old pile of shit...
other than that they run a very long time..
retiredat44 is offline   Reply With Quote
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
1996 Camry V6 Problem redracer_13 3rd & 4th Generation (1992–1996 & 1997–2001) 10 10-12-2007 10:42 AM
Seriously, how strong is the back bumper of the 1996 Camry? *My story* J708 3rd & 4th Generation (1992–1996 & 1997–2001) 29 07-15-2007 05:05 AM
Not sure what year, 93-96 corolla radio/center console lighting problem (Pics) SubaruWRXMike Archived Corolla threads 10 10-20-2004 05:53 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
