Rear speaker size - Toyota Nation Forum : Toyota Car and Truck Forums
post #1 of 15 Old 01-03-2009, 04:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Rear speaker size
Just got a 93 corolla, it originially does not have any rear speakers, i have 2 6 x9's sitting around, would they fit or would i have to get 6.5's?
ironeagle is offline
post #2 of 15 Old 01-03-2009, 04:20 PM
Bitter's Avatar
Quoted: 1406 Post(s)
6x9's can be made to fit.
Bitter is offline
post #3 of 15 Old 01-03-2009, 05:00 PM
Knechts autoparts guy
Quoted: 0 Post(s)
6.5s are the standard size, but i also cut holes for 6x9s
plumpsnake21 is offline
post #4 of 15 Old 03-08-2009, 10:31 PM
Quoted: 0 Post(s)
Any instructions for cutting out the 6x9 holes?
snigma is offline
post #5 of 15 Old 03-08-2009, 10:39 PM
Bitter's Avatar
Bitter is offline
post #6 of 15 Old 03-08-2009, 11:09 PM
Quoted: 0 Post(s)
I have holes in the metal too, but I didn't know if you just had to remove the weird carpet-insulation crap--does it also have wood like yours in the picture?
snigma is offline
post #7 of 15 Old 03-08-2009, 11:30 PM
Bitter's Avatar
no, i made the rings myself and cut the rear cover and carpet myself as well. its not hard (if you know what you're doing and have patience and the correct tools), just a little time consuming.
Bitter is offline
post #8 of 15 Old 03-13-2009, 03:37 PM
Quoted: 0 Post(s)
I don't know about other brands, but when I bought my Audiobahn Speakers, they came with stencils to help with cutting and placing. I just laid my stencils down, lined them up, traced them, then cut out the holes.
rollanub is offline
post #9 of 15 Old 03-16-2009, 11:06 PM
Proud 93 Corolla owner
TI-CAVA's Avatar
Quoted: 0 Post(s)
out there are some wood spacers that "improve" your sound and you can mount it over the stock holes so you can fit bigger speakers than default max allowed, they are covered by some carpet maybe there are other colors than grey.
TI-CAVA is offline
post #10 of 15 Old 03-20-2009, 02:48 PM
Senior TN Member
c_huynh32's Avatar
Quoted: 128 Post(s)
I installed 6.5 in my corolla last month. if you look up in your trunk at your metal brackets, there are 4 spaces. The 2 centers are for the 6x9s and the other 2 are for the regular round speakers.
If you don't want to build your own mounts, you can go to best buy, car audio shop or etc. you can buy speaker brackets to mount your speakers on the OEM metal mounts.
c_huynh32 is offline
post #11 of 15 Old 03-20-2009, 10:48 PM
toysyoda's Avatar
Quoted: 0 Post(s)
Talking
get some "good RMS" full range whizzer cone speakers for the best sound. especially for the door 4"ers.
i hate coaxials. whizzer cones are so much clearer. im thinking about going fostex for mine with the new indash dvd and subs i got. as soon as it warms up again.
another cold spell this week.
toysyoda is offline
post #12 of 15 Old 03-31-2010, 01:42 PM
Quoted: 0 Post(s)
Canada
hey, i have the same car and i was wondering where you wire the speakers to the head unit. because i was going to just install the two rear speakers to see how it sounds before installing an amplifier.
BonyThrone is offline
post #13 of 15 Old 04-20-2010, 12:22 PM
'93 Corolla Owner
Quoted: 0 Post(s)
Canada
I'm about to put rear speakers in my '93 Corolla. When I look via the trunk, I see all the holes for the speakers, and I'm able to cut them out. But, when I recently replaced my stock tape deck with a Kenwood CD Player, and when I was wiring the new radio harness, I noticed that there were wires for rear speakers.
My question being; is there wire running to the back where I can hook my speakers in? Or do I have to do some wiring?
-sheumasonthecoast
Sydney, Nova Scotia, Canada
(1993 Toyota Corolla)
sheumasonthecoast is offline
post #14 of 15 Old 04-20-2010, 03:21 PM
Full Throttle
Kiwi-Corolla's Avatar
Quoted: 15 Post(s)
iTrader Score: 16 reviews
Yep, there will be wires running into the trunk, just under where the hole cut-outs in the metal are. I've got no rear speakers from factory in my Corolla and they're definitely there. If you can't find yours, then take off the back portion of your rear seats as someone may have tucked them under the sides.
Kiwi-Corolla is offline
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
sheumasonthecoast (04-26-2010)
post #15 of 15 Old 04-20-2010, 05:39 PM
AE-202 Owner
miib14's Avatar
Quoted: 0 Post(s)
iv got 6.5 in the sides and 6x9 in the middle and tweeters in the corners
★ 1993 Toyota Corolla Saloon ★
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
195 Bhp & 148 lb/ft Torque
miib14 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
« Back
