crnak shaft timing gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-20-2009, 08:46 AM   #1 (permalink)
View john's Photo Gallery
My sister has a 93 1.8. I went to put a new timing belt and tensioner on, but the crank timing gear is damaged. It looks like the crank key machined about a 30 degree groove in the timing gear. I will try to post pics. I'm not sure how it happened. The key is somewhat distorted. Has anyone else had this with the 1.8? The harmonic balancer seems to be alright also.
john is offline   Reply With Quote
Old 08-20-2009, 09:28 PM   #2 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Previous owner when servicing it may have forced it on? I find it odd and am curious to see pictures.
As long as the key way in the crank is ok, the key is a dollar from the dealer. Id replace it and see if the crank pulley slides on properly and lines up.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 08-21-2009, 03:38 AM   #3 (permalink)
View fast68's Photo Gallery
hmm definiely need to see a pic of what you mean exactly because i for one am confused
it may have been caused by a mechanic who didnt tighten the balancer bolt
or something else could have happened
but im unsure what damage has occured to it exactly
so i dont know what possible causes etc maye be
yet
until we can see a pic or two of it
good luck!!
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
Old 10-07-2009, 05:15 PM   #4 (permalink)
Drop me a line and I'll send the pic. Tried to reduce the size of the pic but still doesn't download. The crank gear wasn't 140 ft/lb tight but it must have been at least 50 ft/lb. Obviously not enough for the timing gear to walk on the crank. Anyway I'll send pics if wanted. 69johng@gmail.com
