94 corolla camshaft frozen, crankshaft & timing belt cranks over - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-22-2009, 03:27 AM   #1 (permalink)
View buzzy's Photo Gallery
Hi All,
I have a 94 corolla 1.8 , I first started out thinking I had an ignition problem. As I dug deeper I popped off the valve cover and noticed when the engine is cranking over the camshaft does not move but the Crankshaft & timing belt does... Any ideas ? Thank you!
buzzy is offline   Reply With Quote
Old 08-22-2009, 09:49 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
broke timing belt, stripped timing belt, loose or broken tensioner.
Old 08-22-2009, 04:09 PM   #3 (permalink)
View fredricktflail's Photo Gallery
If the cam is frozen nothing would move unless the belt is stripped or has no tension
fredricktflail is offline   Reply With Quote
Old 08-22-2009, 06:35 PM   #4 (permalink)
Bitter's Avatar
one other oddball possibility is that the cam gear has broken free from the camshaft.
Old 08-24-2009, 08:40 AM   #5 (permalink)
You asked for it...
View azcorolla's Photo Gallery
X2 - If the belt is actually turning, then this pretty much has to be the problem.
azcorolla is offline   Reply With Quote
Old 08-24-2009, 09:11 AM   #6 (permalink)
View titleist's Photo Gallery
wtf can you turn the cam with a wrench?
titleist is offline   Reply With Quote
Old 08-25-2009, 06:56 PM   #7 (permalink)
Should be able to.
Old 08-26-2009, 11:34 AM   #8 (permalink)
yeah the cam actually snapped on the left side of the seal, everyone @ toyota said they've never seen it before... any one have any ideas what could've caused this? Only thing I could think of was the timing belt was too tight.
Old 08-26-2009, 12:19 PM   #9 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Lightbulb
We have no clue what the history is of the car. When it was run, and how it was running.. how many miles..
but, I can say that it could have had a lubrication problem, a bad bearing, a bent valve stem, the wrong cam part installed, all which can contribute to a broken camshaft.
I once broke a camshaft on a chevy V8 engine, it was the wrong size (thanx to my dad who insisted I try one from a spare engine we had..)
1989 Toyota Corolla SR5, Carb.
1993 Camry LE
retiredat44 is offline   Reply With Quote
Old 08-26-2009, 06:50 PM   #10 (permalink)
Bitter's Avatar
lack of lubrication caused the bearing the seize the cam, pop off the bearing caps for the camshafts and i'll bet they're all marred up and scuffed. lower end bearings may not look very good either.
Old 08-27-2009, 01:52 AM   #11 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
At that point, id find a used motor and grab a case of beer, some friends, and engine lift and swap it out on a weekend.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
