Suspension work DIY thread. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-24-2009, 09:20 PM   #1 (permalink)
4afte FTW
pnyk33's Avatar
View pnyk33's Photo Gallery
Thumbs up Suspension work DIY thread.
First: the website
http://www.tein.com/index.html
Go to SuperPro "click" then "click on
SuperPro
On-Line Vehicle Search
Catalog
This will come up.
http://203.31.191.243/fulcrumCat/
find your car and part #
You can order them anytime through Tein`s website will take about 2 weeks to get parts from Australia.
SPF1900K
THIS IS THE FRONT LOWER CONTROL ARM INNER REAR BUSH- STD
SPF0996K
THIS IS THE FR LOWER INNER FR BUSH
300 HP 4afte
pnyk33 is offline   Reply With Quote
Old 08-24-2009, 09:21 PM   #2 (permalink)
4afte FTW
pnyk33's Avatar
Motor Mounts
http://www.speed-source.net/
well first are the last part# you will need to finish.
Front of car
Part # SPF0832-22K
front swaybar to chassis mount bush kit
Note:
this part is only for the 7afe 1.8 corollas the 1.6 4afe do not have a front swaybar, But you can do a conversion that is what i did. all you will need is the contral arms and sway bar off the same years 1.8 corollas . 93-95 is different then 96-98 corollas.
93-95 style
96-98 style
Rear of car:
Part# SPF0823K
rear lwr t/arm bush kit
Part# SPF2938K
rr ctrl arms inner outer
Note:
this will only work on the 96-97 corollas this is for the CTRL arms that are next to the gas tank the adjustable arms stay OEM.
Note:
Part# SPF1947K
this is all 4 rr ctrl arm bushings for the 93-95 corollas 1.6 & 1.8
300 HP 4afte
Old 08-24-2009, 09:22 PM   #3 (permalink)
4afte FTW
pnyk33's Avatar
the car getting jacked up.
all the parts are ready
First we pulled off the bad axels
plugged the tranny holes
we took off the cross member
and cleaned it to.
300 HP 4afte
Old 08-24-2009, 09:23 PM   #4 (permalink)
4afte FTW
pnyk33's Avatar
we added the new ctrl arms to the cross member
we started to gut out the old motor mounts. as you see my uncle had fun doing it.
We followed J`s institutions and compressed the mounts in with a vice
slaped the mounts in
300 HP 4afte
Old 08-24-2009, 09:24 PM   #5 (permalink)
4afte FTW
pnyk33's Avatar
put in the Whiteline front swaybar
also we put back the cross member and conected the motor mounts almost done with the front
connected the links to the swaybar
now time to put in the new Gator Axles
all done with the front
300 HP 4afte
Old 08-24-2009, 09:24 PM   #6 (permalink)
4afte FTW
pnyk33's Avatar
well time for the rear , first we took off the rear dic and cntrl arms
thanks to my uncle`s bushing remover tool it was fast and easy
i installed the rear whiteline swaw bar. Note: will need to drop the gas tank alittle to slide out the old one and install the new one , slide out through passinger side and repeat.
i clean and painted the ctrl arms to look nice and clean. als we installed the bushings you just need to press them in with your hands. that all.
put it all back together and done.
300 HP 4afte
Old 08-24-2009, 09:29 PM   #7 (permalink)
4afte FTW
pnyk33's Avatar
i was hoping that one of the MOD`s can Thumbtack this to help anyone that is serious about there 7th Gen corollas .
PhatRoyale can you please help a brother out.
300 HP 4afte
Old 08-25-2009, 12:01 AM   #8 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Interesting how the whiteline sway is like the older style sway bar vs the hotchkis coming straight across between the two brackets at the chassis (98-02 kit)
Nice to see the detail and attention you took on the work, much like I do. I used the exact same suspension kit for the tierods, links and joints off ebay, found those links with the dust cap not attached kinda cheap, so they went on the gf's car for the meantime.
I scored a set of trd engine mounts ill be using on my car, ill post pics when I get there and have the suspension apart next as well. Im using trd bushings on the control arms.
Nice to see in california you can get away with the Cusco Coilovers, roads aren't near smooth enough for that around here.
How stiff do you find those solid engine mounts? Did you do the pass side engine mount and the trans mount?
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 08-25-2009, 08:39 AM   #9 (permalink)
View kevmac's Photo Gallery
are these the celica engine mounts?
97' Corolla, CE, 4AFE, 1.6, AT, 4d
kevmac is offline   Reply With Quote
Old 08-25-2009, 08:47 AM   #10 (permalink)
on full afterburner
Gameroom cash: $1345097
How could I not?
Stickied.
Nice work on all the upgrades.
Old 08-25-2009, 04:13 PM   #11 (permalink)
4afte FTW
pnyk33's Avatar
Originally Posted by PhatRoyale View Post
How could I not?
Stickied.
thanks for the love Bro , i hope this helps people out.
No they make a set for the corolla , just need to call them and tell them the year , model , and engine code- 4afe or 7afe.
300 HP 4afte
Old 08-25-2009, 04:18 PM   #12 (permalink)
4afte FTW
pnyk33's Avatar
the side mounts are not needed just the front and backs and it feels great , just a little shaky when presssing on the gas at first but then goes away. but when i boost the car pulls very hard something i did not notice in the beginning when i did not have the better mounts.
300 HP 4afte
Old 08-25-2009, 09:12 PM   #13 (permalink)
How could I not?
Stickied.
score!
edit: other ideas: motor mount instructional, struts how to, how to change brakes, how to properly change spark plugs without F-ing up the wires, how to flush cooling system, change radiator upper/ lower hoses and T-stat.
Old 08-25-2009, 10:33 PM   #14 (permalink)
corolla96's Avatar
View corolla96's Photo Gallery
any difference between the Hotchkis, whiteline and the trd sway bars??which ones are better beside trds??
K&N SRI, TRD FSB, Magnum Steel Braided Brake Hoses, Depo Black Housing Headlights Set, Clear Signal Lenses, 9006 6000K HID, LED corner lights, lic. plate lights, trunk lights, Ractive Sport Pedals, 20% tint front, 5% tint rear, Freeway TCD-0361-1 Deck, custom front grille
corolla96 is offline   Reply With Quote
Old 09-02-2009, 08:44 PM   #15 (permalink)
4afte FTW
pnyk33's Avatar
the Whiteline is great man real stiff on the turns.
300 HP 4afte
