lowering corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-26-2009, 10:59 PM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
lowering corolla
hey guys i just thought i might wanna lower my car a bit its a 94 dx, i was just wondering what kinda stuff i will need to lower it b4 i start buying a buncha random stuff
Derek
dJcHiKo is offline   Reply With Quote
Old 08-26-2009, 11:17 PM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
coil overs
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 08-26-2009, 11:56 PM   #3 (permalink)
View dyce's Photo Gallery
why lower it? just install a body kit and better struts. you will be happier with it. just my input. i work on cars for a living. i get to replace cv axles and try to align lowered cars all the time. i also know that it takes more than a few bits and pieces to safely and properly lower a mcpherson strut suspention setup. ill probably get a rash of crap for knocking on lowered cars, but i can get better cornering and handeling out of a stock suspention than i can a lowered suspention. installing the proper strutts is the first step. air bags are even better because they are tuneable. plus you can lower and raise your ride with a push of a button. besides, if you lower it, you wont have an easy time putting a body kit on it later if you decide to. im not trying to offend, just figured id put in my 2 cents.
dyce is offline   Reply With Quote
Old 08-27-2009, 12:06 AM   #4 (permalink)
coil overs
ok if you go that route i can respect it. it gives you the option to choose your ride hight.
Old 08-27-2009, 01:44 AM   #5 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Coil overs on our roads dont work. Way too stiff.
Buy a good set of struts with a set of lowering springs and be done with it, You will want camber bolts as well to adjust the camber back to spec. Be sure all the bushings are good in the bottom end and replace your inner/outer tie rods and lower ball joints at this time, as if they are slightly worn, they will be shot after a month or two on our roads.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 08-27-2009, 08:18 AM   #6 (permalink)
on full afterburner
Gameroom cash: $1345097
Going to need more information to answer your question.
It depends on:
1). your budget
2), your needs, do you need ride height adjustment
3). your priorities. (ride comfort, handling performance)
4). what are you willing to sacrifice? ie. handling for ride comfort.
Old 08-27-2009, 12:26 PM   #7 (permalink)
jb1830's Avatar
View jb1830's Photo Gallery
I have Tein S-Techs for a 98-02 Corolla got like 2 inches of drop all around with stock everything else. Ride is a little bumpier but if your struts are in decent condition you dont have to change anything else right away. Took like an hour to install myself.
jb1830 is offline   Reply With Quote
