i need help :( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-28-2009, 05:16 PM   #1 (permalink)
View daviidsjdmx's Photo Gallery
i need help :(
been having problems with my car, took out my distributor
opened it up, on the cap there where wires. i changed the sparkplugs,
wires, cap, and the rotor and still same problem. i dont get spark on my #3 wire. is this the cause of the problem and lost of power?
daviidsjdmx is offline   Reply With Quote
Old 08-28-2009, 06:43 PM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
that looks F-word up i bet that's the prob
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 08-28-2009, 07:25 PM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
kind of looks like your cam position sensor was disemboweled by the shaft there.
Old 08-28-2009, 07:32 PM   #4 (permalink)
also i put it back together, put the plugs in made sure they where in tight.
turned on the car and it sounds normal, #3 is getting spark. uhmm ill see what happens when
i warm up the car.
Old 08-28-2009, 07:40 PM   #5 (permalink)
nooB nooB noo
View Larzzzz's Photo Gallery
Looks like you have a bird building a nest on your dist shaft....If you were to remove that nest on the shaft, I bet you'd find 4 flats underneath the the nest.....where did it come from? Answer that question and I bet your problem would be solved.
'06 DCLB Indigo,Scangauge II, Redline tuning hood struts, map light mod, trailer plug mod, LED bed lights Thule X-sporter racks. Aux. back up lights.
Larzzzz is offline   Reply With Quote
Old 08-28-2009, 07:44 PM   #6 (permalink)
Bitter's Avatar
just so we're all clear here, thats copper wire like is used in a sensor winding, coil winding, or electric motor winding and should NOT be wrapped around that shaft.
Old 08-28-2009, 07:46 PM   #7 (permalink)
ohh shit, so that doesnt suppose to be there?!?!?!?!!?!?!?!?!?!?
Old 08-28-2009, 07:47 PM   #8 (permalink)
i really dont know where the hell that came from.......
just opened up my DIS and that shit was there.
Old 08-28-2009, 08:37 PM   #9 (permalink)
View kevmac's Photo Gallery
Probably from below on the stem. I am sure that wire is a coil and needs to be whole and not broken. Buy a new distributor!!!
97' Corolla, CE, 4AFE, 1.6, AT, 4d
kevmac is offline   Reply With Quote
Old 08-28-2009, 09:49 PM   #10 (permalink)
View Corpsey's Photo Gallery
new distributor man, that thing is shot
Corpsey is offline   Reply With Quote
Old 08-29-2009, 06:30 AM   #11 (permalink)
Before "THE WRECK"
sequoiasoon's Avatar
iTrader Score: 7 reviews
View sequoiasoon's Photo Gallery
If that came from ANY one of the sensors currently in there I don't know how it would still be running. I'm thinking something else in there was replaced but that was never removed. I would just try to pull it off first. As for how it works the nub that sticks off the center passed by the magnet and tells it when to fire. NOTHING should be around it and rubbing.
Check the pic http://i700.photobucket.com/albums/w...n/IMG_0084.jpg of what it should look like.
Check your PM also.
'93 Corolla getting parted out. Will be scrap REAL SOON so TELL ME WHAT YOU WANT OR NEED!!! Pictures and videos here http://s700.photobucket.com/albums/w.../parts%20left/
sequoiasoon is offline   Reply With Quote
