How do I hotwire, or do a pushbutton starter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-31-2009, 09:54 PM   #1 (permalink)
View EnvoyLT's Photo Gallery
I loaned my beater 93 corolla to a friend and the ignition jammed on it so I had to chisel it out ssince it wouldnt turn to acc to push the button so I could get the cylinder out. I ended up f*****g everything up so now I am just going to hotwire it or wire a pushbutton starter. Can somebody tell me what each of the wire colors are on the ignition harness?
EnvoyLT is offline   Reply With Quote
Old 09-01-2009, 07:11 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
so you can't even turn to run? or you can turn to run?
Old 09-01-2009, 07:23 AM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
The bad part is even if you get the starter to spin you're looking at two more real issues, a locked streering wheel and a security code.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 09-01-2009, 05:30 PM   #4 (permalink)
View kevmac's Photo Gallery
I was going to by one of these for my next car:
http://cgi.ebay.com/ebaymotors/New-R...Q5fAccessories
You can also get this and run it in line with the ignition wire
http://www.harborfreight.com/cpi/cta...emnumber=92688
97' Corolla, CE, 4AFE, 1.6, AT, 4d
kevmac is offline   Reply With Quote
Old 09-01-2009, 10:48 PM   #5 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
if you drill the lockpin out on the cyl, you can slide the whole old assy out. Then you could even start it with pliers by turning the switch. The switch is bolted to the backside of the cylinder, and you should be able to remove it. You may be able to use it that way, or get a new column from a pick a part. I have a spare column with a key assy if you are interested, not sure on what the shipping might be cross border though even though your like 4 hours away.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 10-27-2009, 02:18 AM   #6 (permalink)
I ended up drilling out the ignition cylinder but I broke part of it so I hotwired it for a while and then finally bought a $5 aftermarket ignition switch for it. I am going to use a dremel to modify the dash to allow the new switch to fit where the old one was. I have the steering lock just kind of jimmy rigged until I get in there and figure out how to totally disable the steering lock.
Old 10-27-2009, 07:15 AM   #7 (permalink)
Bitter's Avatar
what if your jimmy rig fails and the column locks while someone is driving it? do you have any idea how dangerous that could be? your insurance would not cover you, you modified the car in a dangerous fashion and solely you would be liable.
Old 10-27-2009, 09:18 AM   #8 (permalink)
The lock is less likely to go into the lock postition the way I have it than the way it was manufactured. It can't lock if there is no lock. The steering was rigged to stay unlocked for the short drive home and it has and will continue to sit until the steering lock is completely disabled. This car is not a daily driver.
Old 10-27-2009, 04:28 PM   #9 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
thats why you have breaks
sorry im a smart ass lol
Derek
dJcHiKo is offline   Reply With Quote
Old 10-27-2009, 06:39 PM   #10 (permalink)
Bitter's Avatar
having been in a situation where a steering wheel DID lock up on me...its not cool. thankfully i was only in a parking lot and starting to pull out of a parking area. it was a customers car taken for a test drive, the bearing in the steering column locked up due to age/wear. thankgod it locked up on ME in a parking lot and not HIM while going down the road. a freaking small miracle really.
Old 11-01-2009, 12:51 AM   #11 (permalink)
View fast68's Photo Gallery
why didnt you just do it correctly and rmeove the lock the right way ?
wow.
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline   Reply With Quote
