Originally Posted by Bitter
swap distributors, you need the 95 dis with the 95 computer, swap the front pulley and timing cover or whatever else is different to get the cps into place and reading a crank signal.
is the check engine light on or a code stored? is the 95 obd2 or obd1?
okay, I looked at the two motors again just now...I think i might have to changed the oil pump from the 94 engine to the 95 ...the cps I was talking about on the 95 engine has a bolt 10mm holding the sensor into the oil pump...I'll try changing the oil pump, timing cover, crank pulley and dizzy...the ecu/ecm should still be the 95 (inside the car).
Don't take this the wrong way but have you or anyone done this before? I just don't want to get myself into more of a mess when I have the option of returning the used 94 engine....I really want to thing to run...have no choice...so lmk.
thanks
