Free play on steering wheel - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2009, 08:53 AM   #1 (permalink)
View hachuelo's Photo Gallery
My corolla has an excesive amount of free play on the steering wheel,is this caused by worn cv joints,the rack and pinion or both? Thanks.
hachuelo is offline   Reply With Quote
Old 09-09-2009, 02:24 PM   #2 (permalink)
View hungt1999's Photo Gallery
it is probably the outer tie rods
less likely the inner tie rods or the rack&pinion
hungt1999 is offline   Reply With Quote
Old 09-09-2009, 04:17 PM   #3 (permalink)
Ok ,another quick question:My engine mounts are also bad so in this case which should I replace first? the mounts or the tie rods?
Old 09-09-2009, 04:26 PM   #4 (permalink)
Greasewrench's Avatar
View Greasewrench's Photo Gallery
do the tie rods 1st, your tires will wear and you'll have some difficulty steering the car as they get worse.
Greasewrench is offline   Reply With Quote
Old 09-09-2009, 05:34 PM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
sterring wheel play can be from ANY part of the system. Inner and outer tie rods, the rack itself or even the universal that couples the rack to the steering shaft. Have someone move the wheel back and forth while you look for parts that have slop.
-SP
Old 09-09-2009, 06:51 PM   #6 (permalink)
You asked for it...
View azcorolla's Photo Gallery
-SP
X2 - check it carefully first to make sure you replace the bad part and not thw wrong one!
azcorolla is offline   Reply With Quote
