1995 Corolla DX
Is this the stock master key?
I believe I have a Toyota Dealer installed alarm system.
When using the key on the driver's side door - I can't turn it counter clockwise to lock the doors, whys that?
When using the key on the passenger side door - Doesn't lock or unlock. When I turn it clockwise to unlock you can hear the switch/solenoid/motor moving but none of the doors unlock. The lock switch doesn't pop up.
When using the key on the trunk you cannot turn the key either way.
How do the trunk locks work? (The 2 lock switches behind the rear seats). Do the rear seats have to be folded up and the switch set to 'lock' for them to work? I folded both rear seats down and put the switch to 'lock' position but the trunk lever still pops the trunk open.
