Updated: Problem solved for good!
I think I solved this creaking clutch pedal for good.
The clutch master cylinder is bolted to the firewall by two bolts. The floor steel bracket for the clutch pedal is also hold down by the same two bolts plus an extra bolt.
Between the firewall and that bracket, there is that plastic/foam liner. Over time, that liner get squished and shrink, making the assembly somewhat loose.
Therefore, you need to tighten really good these 3 nuts using a 12mm socket. After I tighten those 3 nuts, the creaking disappeared right away!
I also noticed that the clutch pedal electrical switch is installed tightly against the plastic liner, if the pedal bracket is loose, the switch will rub against the liner and that is also contributing to the creaking sound
