The radio code they refer to is just as bitter said, a security code with some radios offered in higher end vehicles so if the stereo is stolen, it can't be reused without it.
You will just need to put in your new battery, need to reset the time on the clock, and program your "preset" radio stations into the radio. That is done by just holding the preset button down once your on the station of choice until it beeps, then its saved.
I would simply replace the battery and then if you still have issues, verify if the fuses are good or not, or come back and we can help you further.
Just make sure not to mix up the polarity when hooking up the battery (would be hard to) but if you do, you will blow the main battery fuse.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
