How to replace brake lines - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-20-2009, 12:58 AM   #1 (permalink)
View mike6886's Photo Gallery
Hi, there i just picked up an 94 corolla 1.6L and i recently notice a leakage of brake fluid. So i go check the master cylinder and the fluid is empty, then i looked underneath where the steel lines are running from the front to rear they are all roted out. How hard is it to replace those lines. Can someone guide me through and give me some tips on replacing brake lines.
Thxs
mike6886 is offline   Reply With Quote
Old 09-20-2009, 08:33 PM   #2 (permalink)
View hungt1999's Photo Gallery
I did that complete job two weeks ago and I suffered so much
all my lines were completely rotten by rust. I applied the brake hard at an intersection and one of my rear brake line burst.
I replace all 5 lines
2 for the rear brakes
one for fuel main supply
one for fuel return
one for the fuel tank to evap canister
I ordered the main fuel line, fuel return and evap line from the dealer, they were pre-bent and those 3 lines costed me $250 CAD
the dealer did not have the rear brake lines until a couple weeks so I ended up buying generic brake steel lines ($10 per roll of 25') with a flaring tool (buy the double flare tool, not the buble flare tool for about $20 at any auto parts store)
I have 2 advices to give you:
- it is a pain to do it without a lift. It was very hard to work under the car on jack stands because of space limitations. Find a garage where you can rent the lift (it costs something like $10 per hour). It took me about 3 complete evenings to do it crawling under the car to change those lines. With a lift, I am confident I could have done it in less than 3-4 hours
- buy the pre-bent lines if you can, you will save so much time. There are so many turns in those lines and it is almost impossible to bent all those lines to match the original turns if you are building them from the generic rolls
all lines except the main fuel are 3/16'' in size. The main fuel line is larger, I suggest you buy at least that one from the dealer because it uses a larger fitting that goes directly to the fuel filter on one end and to the gas tank on the other end.
if you decide to have it done at any garage, it is the labor that will kill you. The parts are not that expensive, it is the time. They will easily quote something like 5-7 hours of labor
oh yes, one more advice, before removing any lines, make sure you know which one is which and mark them carefully where they go.
one last thing, don't remove the main fuel line if you have a full tank of gas or have the replacement parts ready because fuel will keep siphoning out even if you relieve the fuel pressure (the connection fitting is located at an lower elevation than the fuel tank, hence the siphoning effect will keep the fuel flow)
and it goes without saying that you need to bleed the complete brake lines after you change them
hungt1999 is offline   Reply With Quote
Old 07-14-2010, 04:07 PM   #3 (permalink)
View 2004's Photo Gallery
thank you hungt for these generous and detailed instructions!
2004 is offline   Reply With Quote
Old 07-17-2010, 10:53 PM   #4 (permalink)
View redlinerev's Photo Gallery
I just did this as well.
I purchased the lines from the dealer, then took them to a brake shop and had then turn them into 3 pieces each.
The first piece is from the distribution block to the underneath of the car. I fished this down through the firewall from the top, it was a PITA, I cannot even imagine trying to do this as one long piece, even with a lift.
The second piece is the run under the body to the first bend up near the rear, then the third is from there to the wheel cylinder.
No leaks and I am back in business.
Obviously it would be better to have one long piece, but like I said I couldn't image getting them in place correctly. they must put these in well ahead of the engine/tranny/steering on the assembly line.
redlinerev is offline   Reply With Quote
Old 08-26-2010, 08:52 AM   #5 (permalink)
View hgljr1's Photo Gallery
Corolla brake lines
redlinerev. Where did you get the lines. MY local dealer in Morgantown WV that there were none at any dealer in the country for my 1996 Corolla? Thanks in advance. Harry
hgljr1 is offline   Reply With Quote
Old 08-26-2010, 09:55 AM   #6 (permalink)
View 96coroll's Photo Gallery
Same thing happened to me. My dealer said they don't have the pre bent pipes. so i'm just assuming they keep them reserved for there machines only because there a******. they wanted 1,900 to fix all five lines. crappy tire wanted 1000. So what did i do, me and my got coils of line and the fittings and already owned the flair too and did them our selves. No lift it took us about 2 nights. Probally costing use around 85 CAD. Although this is because we already had experience changing the lines on our 89 corolla.
96coroll is offline   Reply With Quote
Old 08-26-2010, 10:28 AM   #7 (permalink)
It is harder to find the rear pre-bent line these days because the car is too old, they don't stock that much anymore because that pre-bent line come in a huge packaging and takes a lot of floor space
Don't give up, doing the bent yourself is definitely feasible, get yourself a bending tool, it helps.
The Following User Says Thank You to hungt1999 For This Useful Post:
2004 (09-08-2010)
Old 08-26-2010, 12:43 PM   #8 (permalink)
yes the bender is a valuable tool i forgot to mention. Although as you will see towards the back there are some intricate bends around the gas tank and frame that are not impossible just challenging at times. It's great that once you angle the pipe in, and for instance it doesn't quite fit by a little bit. the final bend you can do in position with your hands. Just don't push too much and kink it. It's happened to me once.
I recommend to have these lines rust proofed yearly. Because this job if your not able to do yourself is an expensive one at the dealer or garage.
Old 08-28-2010, 10:32 AM   #9 (permalink)
724-318-1234- In Cranberry Baierl Toyota.
I know he still had 1 passenger side line when I picked mine up.
I also ordered my fuel line from them as well. I would try to call them, maybe your guy down there is looking in the wrong spot. I sort of remember the parts guy telling me it was a new part number or something, it took him a few minutes in the system to find them. I think there were 2 listed and 1 was discontinued, so he ordered the other and it was right.
Sorry, I just tossed that receipt last month when I was cleaning out my garage, or I could give you more info.
Old 09-01-2010, 04:04 AM   #10 (permalink)
View 94PrizmDD's Photo Gallery
Wow sounds like alot of work. and for 1900 you can find yourself another car lol. Does this happen in the northern states, due to salt corrosion?
94PrizmDD is offline   Reply With Quote
Old 09-01-2010, 07:08 PM   #11 (permalink)
Ya, i'm sure salt is mainly the culprit. It happened with my 89 and now my 96 corolla. So now i rust proof them ever year because the job is the pain in the ass. my girlfriend just got a 2000 and the first thing i did was rust proof all the lines. They were looking like they are going to be on their way out in about 1 year. I hope i can prevent it for longer.
Old 09-08-2010, 07:29 PM   #12 (permalink)
View Throwdown's Photo Gallery
Check these out!
http://throwdownperformance.com/inde...oducts_id=2188
Throwdown is offline   Reply With Quote
Old 09-08-2010, 09:49 PM   #13 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Originally Posted by Throwdown View Post
not relevant, actually pretty spammy dude. we're talking about the hard lines not the flex lines.
and why would those fit 96-02 and not 93-95 as well? the 93-97 are all the same generation.
