Originally Posted by hungt1999
I don't know for sure but I believe the Prizm and Corolla powertrain and engine parts are interchangeable
how do you know the contacts are bad? the starter just clicks when you start the engine?
did you remove the starter from the car already?
I'm having a false start/Intermittent start problem. I just replaced the plugs, cap, and rotor and it still doesn't start on the first try all the time. It was making a loud clicking sound a few months back but its not as noticeable now.
The battery was replaced a few months ago and the cables are securely attached. I'm going to try changing the contacts and fuel filter and see if that doesn't cure the problem. If not I'll call it a day. The car has never left me stranded it just takes turning it over 2 or 3 times sometimes to get it started.
