TIming belt change?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2009, 06:35 PM   #1 (permalink)
View miller02806's Photo Gallery
Can I do it myself? I have access to the auto hobby shop here where I am stationed, with lifts and all the tools I think I will need. Is it hard on these cars (7a-fe). I plan on changing the timing belt, front main seal, and drive belts. Should I change anything else, like the water pump? What would you change out if you were me? Plan on doing this in the very near future.
Also on a side note...if I lost the damn key thingy for my lock nuts on my rims, where can I find a replacement? I don't even remember where I got the lugnuts.
miller02806 is offline   Reply With Quote
Old 09-26-2009, 08:08 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
the idler/tensioner should be changed also.
Old 09-26-2009, 10:55 PM   #3 (permalink)
View kcfan's Photo Gallery
Thumbs up
check the gaskets while you are at it. if they seem worn change them also. also if you lost the lug nut you can hammer a small socket into the lug nut and try it that way but most tire stops have a tool to remove them.
kcfan is offline   Reply With Quote
Old 09-26-2009, 11:18 PM   #4 (permalink)
View kevmac's Photo Gallery
Yeah that small socket thing works. If you buy a socket with lots of sides and pound it into the lock nut it should bite and spin off easily. Or get a heavy flat head 1/2" bit and use an impact wrench or a breaker bar. And yes do the water pump.
97' Corolla, CE, 4AFE, 1.6, AT, 4d
kevmac is offline   Reply With Quote
Old 09-26-2009, 11:31 PM   #5 (permalink)
Well the locking nut is the variety that has a heart shaped indentation in the middle, not the other type. But when I put new tires on it I will go to the shop that will be able to get it off. Thanks for all the prompt replies...keep em comin'!
Old 10-09-2009, 02:16 PM   #6 (permalink)
View sometoyotaguy's Photo Gallery
I just did mine, and it's alot more work than it looks like, but if you can use the bay then it would probably be cheaper.
I'd replace:
water pump
tensioner
gaskets
front main oil seal
valve cover gaskets
The water pump is a pain to remove. There may be some tricks, but I fiddled with it until I could work it out.
sometoyotaguy is offline   Reply With Quote
Old 10-19-2009, 02:04 AM   #7 (permalink)
ToyotaHankins
View ToyotaHankins's Photo Gallery
make sure you change the spark plug tube seals too because I skipped that and then its started to leak a month later and I had to pull the valve cover again to fix that. alot of people say to do the water pump too but i didn't bother. I service my cooling system regularily and i didn't want to chang the pump. the first time always takes longer but any time after is a breeze.
ToyotaHankins is offline   Reply With Quote
Old 11-03-2009, 01:56 PM   #8 (permalink)
View moh2o's Photo Gallery
Me too
Hi, all I am new here and I am doing the same on my 96 Corolla wagon, with the 1.8 liter 4cly.
Hey I was wondering if I really need to replace the tensioner at 124,000 miles?
I mean is it all worn out by then? It costs $150 out here in cali. Don't mean to hijack, thought it might be good info to for the original poster too.
I am for sure doing all the other stuff like the
-front seal
-gaskets for cover and valve cover
-water pump, 4 sure
-and of course the timing belt
I have done this before on Honda cars back in the early 80's, when it was real easy. Are these 7th gen toyo's very hard ?
moh2o is offline   Reply With Quote
