95 4A FE engine in 96 (crank sensor bypass?) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2009, 08:05 AM   #1 (permalink)
View gto69's Photo Gallery
I had to change my 96 4A FE 1.6l in my corolla and found a 95 corolla 4A FE.
After some inspection I found that there 2 major differences between the engines. First is the EGR system but that is no problem since i will swap the complete intake from my 96 to the 95 engine.
Second thing is the crank sensor which is missing on the 95 engine. How can I bypass this or can i simply swap the oil pump cover to the 95 engine to have the crank sensor. The only visible differnence is the casting to allow the installation of the sensor. But what about the rest, is the oil pump interchangable.
Also is the 96 distributor fit wihout any problem the 95 engine
Thanks!
gto69 is offline   Reply With Quote
Old 09-30-2009, 12:33 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
The oil pumps are interchangeable, you should be able to just swap the cover and reuse the sensor. As far as the distributor, it should fit.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
