Manual Tranaxle Drian and Fill Points? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-02-2009, 05:15 PM   #1 (permalink)
Clean & Simple
TLToyota's Avatar
View TLToyota's Photo Gallery
Is this the bolt to fill up the transaxle?
Where is the bolt to drain it?
How do i tell when its full?
1995 Mustang Cobra
Cobra Engine Bay
Fav Pic
1981 T-Top Mustang Coupe
1993 Corollin - Daily Driver
TLToyota is offline   Reply With Quote
Old 10-02-2009, 05:37 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
I think there's a plug on the side, you basically just put gear oil in it until it spills out. Unless the transmission oil looks bad, you don't need to change it.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 10-02-2009, 05:39 PM   #3 (permalink)
Clean & Simple
TLToyota's Avatar
Ok... ill look around.
Is the drain plug a BIG bolt on the bottom?
1995 Mustang Cobra
Cobra Engine Bay
Fav Pic
Old 10-02-2009, 05:49 PM   #4 (permalink)
Official TN Toaster
iToaster's Avatar
I'm willing to bet it is, should be about 14mm.
RIP white Corolla
Old 10-06-2009, 04:11 PM   #5 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
The drain bolt is a 24mm bolt on the very bottom of the transmission case. The fill bolt is on the front side of the transmission about half way up and uses a hex key/driver to remove and replace. When you do this service, its advisable to have the replacement crush washers handy to replace them. When reusing them, they sometimes end up seeping due to having been over compressed and cracking.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
