'97 Corolla rear brake shoe replacement instructions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2009, 11:35 AM   #1 (permalink)
View jeanv's Photo Gallery
We have a '97 Corolla originally made in Canada. Needs new rear brake shoes. It is college son's car--husband decided to do repair with son and ran into problems--discs were stuck due to rim erosion--got disc off and now there seems to be issue with shoe adjustment part.
where can we find a step by step how to instructions on replacing rear shoes on this year? Worst case need to get one back together to drive to dealer for their help.
jeanv is offline   Reply With Quote
Old 10-03-2009, 12:29 PM   #2 (permalink)
View kevmac's Photo Gallery
They're drums not discs, and you need to replace them. Check autozone.
You should have taken a picture before dismantling it.
take pads, springs, adjuster off. Spray a ton of brake cleaner all over the housing until everything is clean. Get new drum pads, drum hardware kit, adjustment screw, drums. Inspect the wheel cylinders and replace if uncertain (not very expensive, autozone, pep boys). Take your time replacing the stuff (that's where the picture helps). Put grease where the pads metal touches the housing. The e brake cable is a little work to get on right and might require a special pair of pliers to grip it right. After it is all back on right, use two flat head screwdrivers to move the wheel with teeth on the adjustment screw away from the locking bar. Place the drum on the hub after each time to see if it is snug- no play but able to slide on without hammering it. Pull your ebrake to adjust once the wheels are back on.
97' Corolla, CE, 4AFE, 1.6, AT, 4d
kevmac is offline   Reply With Quote
