I got new Tach - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-04-2009, 07:56 PM   #1 (permalink)
koloheboy88's Avatar
View koloheboy88's Photo Gallery
gen 7 I got new Tach
I have a new-ish tach and it says to get light from it you need to connect this wire to the instrument panel light circuit, But i dont know where its at. I dont have my repair manual with the wiring diagram. can anyone help me out?..does anyone have a wiring diagram? i need to find a good source for power from the fuse box that cuts out when i turn the car off.
koloheboy88 is offline   Reply With Quote
Old 10-04-2009, 08:33 PM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
So, do you want the tach to light up all the time, or just when the parking light is on? A great, easy place is behind the radio... there are wires there for both power sources. If you replaced your radio, this should be no problem for you!
gold94corolla is online now   Reply With Quote
Old 10-04-2009, 11:23 PM   #3 (permalink)
yea its a aftermarket radio. how and where do i put the wire? i didnt put the radio in..and which spot do i put the the power wire in the fuse box? i know each number means somthing. just dont know what..
Old 10-05-2009, 06:00 PM   #4 (permalink)
Oh, if you didn't install the radio, maybe the wires aren't marked.... you could pull out the radio and see what the wires look like.... I can't remember what the wire colors were, though...
Let's see, found an old pic
It might not help much, but on my radio wires, you can see that they are labeled. Looking at this pic, I remember. The red fused wire is the ignition/key turn power. The yellow wire is the battery. The black wire is the ground.
Old 10-05-2009, 10:37 PM   #5 (permalink)
this helps out alot! so i can splice power to the battery wire and the lights to the ignition on/off wire? and of course the black to the ground..or my power to the on/off wire and the lights to the battery wire...i confused myself..do you know what im trying to say? I have 4 wires..red(power),black(ground), green(distributor),and white is the lights..
Old 10-08-2009, 01:30 AM   #6 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
This is the wire diagram for the entire car.
Radio Constant 12V+ Wire: Blue/Yellow (aka Battery)
Radio Switched 12V+ Wire: Gray ( AKA Ignition)
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 10-08-2009, 06:51 PM   #7 (permalink)
No, you don't want to wire anything to your battery.... i believe. The power should be to the red wire, and the lights should wire to the parking/night light. This way, the tach will have power when you turn on the engine, and it will light up at night with the first head light switch turn. The distributor wire, you know where to run that? You might have the wire at the tachometer already.... if not, the wire goes here:
If you look under the hood and you see 4 wires already, you have the wire behind the gauge cluster. I did, so I just swapped the tach cluster in and it worked.
If you need to run a distributor wire, check here:
http://www.cardomain.com/ride/2665752/7
Old 03-18-2010, 08:13 PM   #8 (permalink)
Lanuza_fox's Avatar
View Lanuza_fox's Photo Gallery
Did you ever wire up you aftermarket tach? do you have pics of where you wired it if you did?
Lanuza_fox is offline   Reply With Quote
Old 03-18-2010, 10:03 PM   #9 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
I sure would love to get a factory tach cluster for our Rolla. I can't stand not seeing the engine speed even if it is a POS slushbox. But I hate aftermarket tachs up on the pillar worse
PatrickGSR94 is offline   Reply With Quote
Old 03-18-2010, 11:52 PM   #10 (permalink)
In that image... just wire it to the black wire, under the green one... that is where I wired my monster tach in my old rolla. see here -
Corolla Number TWO
Old 03-19-2010, 11:12 AM   #11 (permalink)
on full afterburner
Gameroom cash: $1344797
Just look for an LE cluster at a local junkyard or on ebay, they pop up from time to time.
Old 03-19-2010, 01:30 PM   #12 (permalink)
Yeah I looked for one once (did a similar swap on my old base Camry), but didn't like the prices I saw
Old 03-22-2010, 03:28 AM   #13 (permalink)
Lanuza_fox's Avatar
I got my tach but my corolla has two connectors by the distributor. one with 2wires and on with 6 wires. mine is the 1.6L. the pics show a 4wire connector. which one do i use in the 1.6L
Old 03-22-2010, 09:59 AM   #14 (permalink)
Sine Deviance's Avatar
View Sine Deviance's Photo Gallery
You're preaching to the choir, brother! Local boneyards want $100+ for an instrument cluster and EBay isn't any better. I could probably build my own for less than that
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline   Reply With Quote
