help needed: upper timing belt cover removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2009, 09:28 AM   #1 (permalink)
View hungt1999's Photo Gallery
I want to remove the upper timing belt cover to inspect the timing belt.
I removed the 4 bolts on the upper timing belt cover but can't get the cover out because the upper part seems to slide under the valve cover
do I need to remove the valve cover too?
hungt1999 is offline   Reply With Quote
Old 10-08-2009, 02:30 PM   #2 (permalink)
Greasewrench's Avatar
View Greasewrench's Photo Gallery
yeah, at least that's how it went for me when i took timing covers off. the valve cover and all 3 timing covers fit together like puzzle pieces, they don't just slide off. u need to remove the valve cover to be able to access any of the timing covers and since it has a gasket on it and RTV sealant at each corner, u may have to wrestle with it a little before it comes off.
Greasewrench is offline   Reply With Quote
Old 10-08-2009, 04:51 PM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Yes, as gw said, remove the valve cover. Won't need to remove anything else to inspect it.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 10-08-2009, 08:49 PM   #4 (permalink)
If I need to remove the valve cover, that is bad news for me. A while ago I tried removing the valve cover but gave up because it was so stuck even tapping a wood block with a small sledge hammer, I could not even get it to move
maybe I will try again and like someone mentioned in another thread, the rubber grommets that sits below the head cover bolts need to be pryed out too to be able to tap the valve cover loose
Old 10-08-2009, 09:17 PM   #5 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
There's 4 nuts on top of the valve cover to remove, 2 bolts on the cover running over the alternator cable, and one on the hook on the back that needs to loosened to let the cover move up. It shouldn't be that hard to get off.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 10-09-2009, 01:55 PM   #6 (permalink)
View sometoyotaguy's Photo Gallery
I found that the rubber grommets underneath the nuts turned rock hard, and had to be "unscrewed" with a flat screwdriver and a small hammer.
My Cover wouldn't budge either until I noticed that.
Good luck
sometoyotaguy is offline   Reply With Quote
Old 10-19-2009, 02:08 AM   #7 (permalink)
ToyotaHankins
View ToyotaHankins's Photo Gallery
yeah it took me a while to figure out that those rubber grommets under the nuts were holding down the valve cover.
ToyotaHankins is offline   Reply With Quote
Old 10-19-2009, 09:13 AM   #8 (permalink)
If I remove the valve cover, do I need to put RTV sealant after when I re-install the cover?
I have never used that RTV sealant before, in what areas should I put it?
there is a rubber gasket that goes around the cover right? do I put RTV sealer on the rubber gasket?
Old 10-21-2009, 10:21 AM   #9 (permalink)
yes u do need to reapply RTV sealant if u take it off and want to put it back on again. u only put the sealant on 4 areas of the cylinder head, if u get a haynes manual it shows u exactly where to put it. RTV is like a thick black toothpaste but it dries very quickly (a matter of minutes to be exact) to a silly putty-like consistency. u can get it from the dealer for $18 a tube its called FIPG (Formed In Place Gasket). do not apply the RTV to the entire rubber gasket, only to the areas outlined in the haynes manual, 4 spots i believe in the 4 corners of the cylinder head. u gotta get the manual to do it right man or else u may get oil leaks.
